Fuel pump relay issues. - JeepForum.com
post #1 of 2 Old 03-26-2012, 02:23 PM Thread Starter
robert644
1989 XJ Cherokee
Hello,
Well, I am trying to make my poor 89 XJ get up and go, but it is one thing after another apparently. I replaced my leaky original injectors with nice Bosch 00280155746 ones, but then developed a leak at the rail/hose fitting. Of course no one knows what a fuel line quick disconnect kit is here in town.
After solving that, my fuel pump up and gave up. There is power to the relay, and I can jumper the connections and make the pump go, however nothing with the relay - except
When I initially turn the key, the pump fires up for about a second, then quits and stays off. If I bleed the system with the fuel pressure testing port, the pump does not kick in to maintain pressure, and I don't recall seeing anythihng about a pressure switch anywhere in the system anyhow.
Also, if I hotwire the switch, the vehicle still doesn't want to start.
The longer I own this car, the more I realize I can't give up on it, for all the time and effort put into the thing, and the specific knowledge about it! I hope this isn't a bad ECU though, and perhaps I need to just hotwire the thing as the ignition key switch gave out some time ago.
Thanks for your help and time.
robert644 is offline
post #2 of 2 Old 03-26-2012, 03:28 PM Thread Starter
robert644
1989 XJ Cherokee
So I read that when turning the key, there is an initial prime, after which the pump shuts off. Then it reactivates during cranking. Vehicle will still not start, and testing indicates voltage to the coil. I guess I will pull out my spark tester next!
fuel pump , relay , voltage
Fuel pump relay clicks, pump doesn't run RogerRoger XJ Cherokee Technical Forum 9 07-19-2015 10:41 AM
fuel pump relay jeep12827 XJ Cherokee Technical Forum 1 07-04-2008 03:05 PM
where is my fuel pump relay????? extreme69 XJ Cherokee Technical Forum 6 04-28-2008 06:24 PM
How to test: fuel pump relay or pump itself? tombob XJ Cherokee Technical Forum 0 11-11-2007 09:53 AM
Why a fuel pump relay output on my A/C Relay twisted_ed XJ Cherokee Technical Forum 0 04-02-2005 02:11 PM
