Fuel pump issue - JeepForum.com
post #1 of 3 Old 09-03-2012, 09:36 AM Thread Starter
Mary111
This will be my first post I have started fixing up a 97 Grand Cherokee Laredo. It has been sitting in a pasture for about 5 yrs. The engine wants to turn over and if i spray some startup fluid in it it will start for about 10 seconds until fumes get burnt up.....I cannot hear the fuel pump kick on so I checked the fuses and there all good I replaced the fuel pump relay and the asd relay....I replaced the fuel pump...still wouldnt power on so I check to make sure Im getting 12v at fuel pump when i crank engine.....so i though i had a defective fuel pump...I took it back and swapped it out still wont power on...any ideas what else to try.................
Mary111 is offline
post #2 of 3 Old 09-04-2012, 09:34 AM Thread Starter
Mary111
I have found my issue i replaced the distributor cap and rotor and car started......If anyone has this issue where fuel pump won't power on......I would first check if u have voltage when u crank the engine AND when u power it on for about 2 seconds ........if not getting power with just turning key on I would go for distributor cap before replacing the fuel pump......like I did.....
Mary111 is offline
post #3 of 3 Old 09-04-2012, 07:18 PM
CCKen
CCKen's Avatar
CCKen is offline
fuel pump , help needed , issue , won't start
Fuel pump issue RYoung1 XJ Cherokee Technical Forum 3 02-02-2012 09:20 AM
fuel pump issue.... itsmejonnyb MJ Comanche Technical Forum 4 06-12-2009 08:40 PM
'91 4.0L XJ fuel pump issue Mean Max XJ Cherokee Technical Forum 2 05-14-2009 12:13 PM
Fuel Pump issue!! BustedKnuckleXJ XJ Cherokee Technical Forum 3 04-30-2008 01:10 PM
Fuel Pump Issue Please Help:-) forgottenwave XJ Cherokee Technical Forum 3 04-03-2007 10:35 PM
