fuel pump failure symptoms? - JeepForum.com
post #1 of 4 Old 10-19-2007, 12:39 AM Thread Starter
motu1983
1989 XJ Cherokee
hey what are common symptoms of fuel pump failure/getting ready to fail? i've got a rattle/ticking noise that comes from the rear of the XJ whenever i startup or when it idles. If i'm at a stop, once i start rolling i get a rattle that picks up the pace as i accelerate until i hit about 35mph. i'm just wondering if it might be the fuel pump since nothing visible is making any sort of contact under the xj near the rear. I thought it might be the exhaust at first since my eclipse did that for a while and the exhaust was the culprit but the exhaust is free and clear of anything metallic that could rattle. am i right in diagnosing the fuel pump or am i way off? also, it primes when the key is in on position and there are no fuel problems other than my guage dropping about a quarter of the way down when i hit the gas (if i'm at full tank, it will read full, but as soon as i hit the gas pedal the needle drops down to 3/4), then slowly climbs back up to wherever it just was as its cruising.
1989 Jeep Cherokee Laredo - "Ironhide"
Rattlecan Black paintjob, trimmed fenders/deleted flares -dropped rear driveshaft - currently a 2 ton paperweight
1993 Jeep Grand Cherokee - "Purple Haze"
4.0, Stock everything, girlfriend's ride, Girly Purple/silver paint (Girlfriend's)
motu1983 is offline
post #2 of 4 Old 10-19-2007, 01:08 AM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
I'd think it might be the heat shield on your stock muffler or cat that's loose. Also check the exhaust mount at the cross member.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
balloo93 is offline
post #3 of 4 Old 10-19-2007, 12:06 PM Thread Starter
motu1983
1989 XJ Cherokee
ok, will do. thanks balloo.
motu1983 is offline
post #4 of 4 Old 10-19-2007, 12:53 PM
mrboom
1995 XJ Cherokee
Dont you just LOVE Jeeps?
Mine does the same thing and always has..
X2 on the exhaust. Cat might be shot and the brick is rattling around inside.
My Jeep Hates Me..
95 Sport. 4.5 homebrew lift.. *Bastard Pack and loving it*
Everytime a Commander Roles off the Lot, a Cherokee Dies.
mrboom is offline
XJ Repeated fuel pump failure alexf XJ Cherokee Technical Forum 1 05-16-2009 03:41 PM
AW4 Trans failure symptoms? kadetklapp XJ Cherokee Technical Forum 7 05-13-2009 12:00 PM
oil pump priming ---> failure 97babyxj XJ Cherokee Technical Forum 1 11-02-2008 09:02 AM
symptoms of bad fuel pump ar275103 XJ Cherokee Technical Forum 6 07-08-2007 08:59 PM
External fuel pump for backup in case of failure?? jdilpkle XJ Cherokee Technical Forum 4 10-12-2006 03:40 PM
