fuel pump ballist resistor bypass relay - JeepForum.com
post #1 of 4 Old 02-18-2010, 04:17 PM Thread Starter
dancinbills
1993 FSJ Cherokee
i have a 93 jeep cherokee country 4.0 litre and the fuel pump ballist resistor bypass relay is shot. can i connect direct or will it cause damage to the fuel pump. or can i put a 1.2 ohm one in or will it hurt the pump. need answer as quick as possible as this is our only vehicle.
dancinbills is offline
post #2 of 4 Old 02-18-2010, 04:21 PM
tangofox007
Bypassing the resistor on a temporary basis should not be cause for concern. Later models don't have them in the first place.
tangofox007 is offline
post #3 of 4 Old 02-18-2010, 04:51 PM
mecompco
www.midcoastjeep.com
mecompco's Avatar
1994 XJ Cherokee
Just bypass it. My '94 Country does not even have one. From '94 or so on they just run at full voltage all the time.
'94 Cherokee Country
Engine: 4.0 HO, Sealed canister filter, 3 core CSF steel radiator, CatCo cat, Dynomax Turbo Flow muffler.
Electronics: Remote start/locks, Pioneer DEH-P7800MP w/XM, Polk Audio speakers, Garmin Nuvi 660 GPS, Cobra 148 GTL P&T w/Wilson 1000.
Suspension: Old Man Emu 3" lift+OME AAL, JKS adjustable trackbar, QDs, LCAs UCAs, A.C.O.S., DPG Offroad adjustable bumpstop plate, Daystar poly bumpstops.
Steering: Currie HD steering, C-ROK steering box reinforcement, OME stabilizer.
Armor/Recovery: T&T Custom belly skid, Mopar gas tank skid, JKS LCA mini skids, Rock Lizard Super Skink Sliders, Mopar 2" receiver, ARB Bull Bar/Ramsey REP 8.5 winch.
Drive train: D30 front axle w/Superior Chromo D30 axles & outter seals, D/S 4.56 R&P, ARB locker, Ruff Stuff cover. Ford 8.8 rear axle w/Superior Super 88 kit, Ford Motor Sports 4.56 R&P, ARB locker, SOLID cover, Russell stainless lines. Front and rear Tom Woods HD drive shafts, 242 x-fer case w/Tom Woods SYE.
Tires/Wheels: 33x10.5x15 BFG Mud Terrains on Alcoas.
Misc: Garvin Wilderness rack, Safari Snorkel, Redline Tuning hood lifts.
Awaiting installation: Autometer A pillar gauge pod, oil, water, & tranny temp guages, PIAA driving lights, Goferit tie-rod flip bushing, '95 Brake booster and M/C, M.O.R.E. Motor mounts, TnT Custom 1.5" Shackle.
Stroker Project: HO Block, '99 intake manifold, bored TB, 1" TB spacer, Dynomax Blackjack Header, Permacool electric fan.
mecompco is offline
post #4 of 4 Old 02-18-2010, 05:12 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
The only drawback to bypassing it will be a little more noise from the fuel pump.
xjfever is offline
Fuel pump relay clicks, pump doesn't run RogerRoger XJ Cherokee Technical Forum 9 07-19-2015 10:41 AM
Fuel Pump Ballast Resistor Untouchable XJ Cherokee Technical Forum 10 02-04-2010 05:31 PM
Start but no run..ASD...ballast resistor...or pump relay? Laodicea XJ Cherokee Technical Forum 4 02-19-2008 02:35 PM
fuel pump resistor. 88wagon XJ Cherokee Technical Forum 13 12-18-2006 07:11 PM
Why a fuel pump relay output on my A/C Relay twisted_ed XJ Cherokee Technical Forum 0 04-02-2005 02:11 PM
