Fuel Pressure reading..Help!! - JeepForum.com
post #1 of 6 Old 07-09-2010, 08:10 AM Thread Starter
bcusstc
Having troubles trying to figure out what the %%%% is wrong with my XJ.
Ive done fuel pressure readings and it is 31ish with vacuum plugged in and it bounces from 31-38ish with vacuum unplugged, Wasnt sure if that should be a steady pressure or if its suppose to bounce up and down from 31-38ish.
she idles great, Starts great, just can NOT figure this out..
Ive done new plugs, wires ,rotor cap ,distb cap, fuel filter, tps, IAC, New grounds, ive unplugged and reset the CPS, replaced the fuel relay, 02 sensor,
as soon as i give it gas it will go but it has a hesitation or surge that just seems fuel related. i can floor it and it will hesitate a little bit but it will still accelerate.
Will a clogged strainer give me these hesitation issues?
Any help would be greatly appreciated.
bcusstc is offline
post #2 of 6 Old 07-09-2010, 08:45 AM
Paradise XJ
1988 MJ Comanche
Did you adjust the TPS? On your RENIX the TPS is adjustable and should be adjusted when newly installed. That sounds like what your problem is.
http://www.greatlakesxj.com/tech/TPS.html
If you have 31 psi on the schrader valve, you should be good, doesn't sound like a fuel issue.
How did you "reset" the CPS(CKS)??
1990 XJ Laredo - White & Chrome
1988 MJ Pioneer - Metallic Green and Black
Paradise XJ is offline
post #3 of 6 Old 07-09-2010, 08:56 AM Thread Starter
bcusstc
i didnt adjust the tps i took it out of another running cherokee to be honest.
but i did check my tps before and it checked out ok.
I had unplugged the battery and the CPS for a few minutes to see if that would help as well.
i can rev it up all i want with no problems no nothing. sounds great no issues what so ever. its when i put it in drive and go do i get the hesitation. Coil maybe? Should the pressure jump up and down with the vacuum unplugged?
bcusstc is offline
post #4 of 6 Old 07-09-2010, 01:32 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
You absolutely have to adjust the TPS. Stop all other plans, diagnoses etc etc and adjust it with a voltmeter. Otherwise you are just peeing into the wind.
cruiser54 is offline
post #5 of 6 Old 07-09-2010, 02:57 PM Thread Starter
bcusstc
after running a volt meter on it, it shows me 4.5 volts going in and 3.8 coming out.
bcusstc is offline
post #6 of 6 Old 07-09-2010, 04:48 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
With that input voltage, it should be 3.78V coming out. Always take your input voltage and multiply it by .83 to get the proper output voltage on an automatic. Time to adjust your messed up TPS.
fuel , pressure , cherokee
What can cause a high oil pressure reading jeepfever87 XJ Cherokee Technical Forum 16 09-14-2014 06:21 PM
Oil Pressure Gauge reading MAX 80... Sensor? JohnnyX XJ Cherokee Technical Forum 3 02-14-2009 05:38 PM
no oil pressure reading drvn93 XJ Cherokee Technical Forum 7 12-16-2008 12:28 AM
Engine Oil Leaks and high reading on oil pressure gauge KYJeepGirl1980 XJ Cherokee Technical Forum 1 07-15-2008 09:48 AM
Oil Pressure Gauge not reading... blue176 XJ Cherokee Technical Forum 3 07-04-2007 08:50 PM
