Fuel line quick disconnect replacement options - JeepForum.com
post #1 of 4 Old 08-13-2017, 06:58 PM Thread Starter
AdamRice
1998 XJ 4.0 AW4
There is a section in the fuel line with a quick disconnect fitting where it comes off the frame and goes up into the engine bay. It is badly rusted and I am searching for replacement options.
The line is stainless up until the quick disconnect fitting, then it turns into Nylon for about a foot, and then back into stainless steel. Can I just cut the rusted section out and splice in a section of high pressure fuel hose with hose clamps?
AdamRice is offline
post #2 of 4 Old 08-13-2017, 10:58 PM
kycherokee1239
Why not fabricate a splice using AN fittings and Stainless covered line? https://www.anplumbing.com/
2000 Sport. 4.0 C 8.25 LSD. 242 TC. 111,000 miles. (Just Empty Every Pocket!)
2000 Sport. 4.0 C 8.25 LSD. 242 TC. 105K miles. (Just Empty Every Pocket!)
kycherokee1239 is offline
post #3 of 4 Old 08-15-2017, 07:51 PM Thread Starter
AdamRice
That certainly is a more professional option, but I don't have any experience using these types of fittings. There are many different fittings on that website. Can you be more specific about which pieces I would need?
AdamRice is offline
post #4 of 4 Old 08-18-2017, 03:44 AM
kycherokee1239
My suggestion is NOT the least expensive way to accomplish what you want to do. I have not had long term success with screw-type clamps holding rubber fuel line on a hard line. Using the link in my previous post I put together a parts list of what you would need. The size here is only a suggestion. The size of the fittings is dependent on the OD of the fuel line. (The site has a decent tutorial video). Earls is one brand, Russell is another. I know that Pep Boys carries AN type hardware. You would need 2 line fittings: 165064ERL. 2 Hose fittings: 300106ERL. And whatever length hose; Hose 300006ERL.
