Fuel Issue - JeepForum.com
post #1 of 7 Old 05-12-2010, 05:52 PM Thread Starter
perrysjeep 98
Fuel Issue
I have a 98 cherokee classic lately its been bogging down when I push it to the floor. I checked the fuel pressure today and found that whith the key turned on but not cranking the motor I get 33 psi, when i start it and let it idle the fuel pressure drops to 31psi, and when i go to wide open throttle it drops down to 28 psi. I don't think these are good readings.
My question's are does my jeep have a fuel pressure regulator, and does it sound like the fuel pump needs changed? Thanks for any advice
Rusty's 6.5in lift
36 12.50 Swampers w/Crager soft 8s
adj lower and upper control arms, Rusty's HD tracbar. Dynomax super turbo exhaust,Dana 44 w/Yukon 4.88 gears
perrysjeep 98 is offline
post #2 of 7 Old 05-13-2010, 10:23 AM Thread Starter
perrysjeep 98
Can anyone tell me if i'm on the right track
Rusty's 6.5in lift
post #3 of 7 Old 05-13-2010, 11:06 AM
thenewguy88
1997 XJ Cherokee
my jeep is running kind of funky too. It takes a long time to build fuel pressure during start up and idles sort of rough once it is running. I think i'm gonna start with a new fuel filter. How long has it been since you changed your fuel filter?
thenewguy88 is offline
post #4 of 7 Old 05-13-2010, 12:34 PM Thread Starter
perrysjeep 98
I replaced the pump and filter 2 years ago.
Rusty's 6.5in lift
post #5 of 7 Old 05-13-2010, 12:49 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Originally Posted by periscope 98 View Post
.... question's are does my jeep have a fuel pressure regulator, and does it sound like the fuel pump needs changed? Thanks for any advice
The fuel pressure regulator is part of the pump assembly. Purchase a good quality replacement fuel pump assembly. As you are finding out, the cheaper fuel pumps don't last very long.
CJ7-Tim is offline
post #6 of 7 Old 05-15-2010, 08:07 AM Thread Starter
perrysjeep 98
I just replaced the fuel pump assy and the jeep runs like it should.
Rusty's 6.5in lift
post #7 of 7 Old 05-15-2010, 10:11 AM
DerMeister
Yeah, I think normal is 45 +/- 5. In the 30's and I would be changing mine too.
DerMeister is offline
bogging , fuel
Fuel Issue?? Need Help!!! klock89 XJ Cherokee Technical Forum 9 11-14-2009 10:35 PM
fuel issue nashbs XJ Cherokee Technical Forum 6 09-10-2009 03:35 PM
Fuel issue Lew360 XJ Cherokee Technical Forum 10 11-23-2008 07:30 PM
Fuel MPG issue... Bleed4MJ XJ Cherokee Technical Forum 8 10-08-2008 01:42 PM
Fuel Issue??? Beachjeep77 XJ Cherokee Technical Forum 6 08-13-2008 06:28 PM
