Fuel injectors - JeepForum.com
post #1 of 6 Old 11-25-2016, 07:55 AM Thread Starter
Wheels447
1988 MJ Comanche
Fuel injectors
I have a 1988 jeep Comanche 4.0 I want to do a fuel injector swap to the 4 hole injector what would be the best and easyist to do
Wheels447 is offline
post #2 of 6 Old 11-25-2016, 08:06 AM
PimaXJ
1997 XJ Cherokee
Do a search here or out there, plenty of information on the topic. Got mine out of a mid-nineties stick shift Neon. Only concern for you would be the type of connectors on the harness.
PimaXJ is offline
post #3 of 6 Old 11-25-2016, 04:22 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
http://cruiser54.com/?p=438
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #4 of 6 Old 11-25-2016, 07:36 PM
ou2mame
I bought rebuilds off ebay. They work great. I had a leaking one, it was cracked and spraying gasoline. From what I've read, it really doesn't make any difference if your engine is stock, so it's not much of an upgrade. If yours are clogged and causing misfires or something then sure go for it.. But don't expect a world of difference if your current ones are fine.
Sent from my HTC M9 using Tapatalk
ou2mame is offline
post #5 of 6 Old 11-25-2016, 08:51 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Which injectors did you get/
post #6 of 6 Old 11-26-2016, 04:30 PM
ou2mame
I have a 99, so they would be different than yours, but they were just some rebuilt Bosch 4 holes off ebay.
ou2mame is offline
