Quantcast fuel injector/fuel rail question - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > fuel injector/fuel rail question
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire Carrier
Old 11-16-2007, 09:02 AM   #1
LeeBee
I'm in the middle of changing out the manifold in my 99 xj, and upon removing the fuel rail/injectors from the top of the intake manifold 2 of the injectors came apart from the fuel rail. I've been spending way too much time trying to get those injectors back into the hole on the fuel rail where they belong but no luck. Those little o rings don't seem to want to compress enough(under human strength anyway)to pop back into place. Does anyone know what I'm talkin about and what is the trick? Is there a compression tool of some sort used to seat the injector properly? Much appreciation to the one or ones who can help.
LeeBee is offline   Reply With Quote
Old 11-16-2007, 09:23 AM   #2
alexrule123
Universal Cereal Bus
alexrule123's Avatar
I had one injector pop out and it is a pain to get it back in but i just pushed it in and i think i tried rotating it while pushing it in. It took me a few times to get it back in but it finally went back in.
1999 Cherokee Classic: R.I.P. http://www.cardomain.com/ride/2313036
2001 Cherokee Limited My Build Thread: 6" IRO Long Arms and coils, JKS ACOS, OME 4" Leaf springs w/1.5" Teraflex shackles, RC Shackle Relocation Brackets, ~34" BFG KM2, RC Quick Discos, Fox 2.0 IPF Shocks, Rear Disk Brakes, 60mm Bored TB, Cobra Injectors, Rugged Ridge Header, 2.5" Exhaust with Borla Muffler
alexrule123 is offline   Reply With Quote
Old 11-16-2007, 10:08 AM   #3
LeeBee
Alot of relief and a little embarassment.., immediately after my 1st post I tryed it again and this time for the hell of it I used a small amount of grease on the o rings and aroung the opening on the rail, and wouldn't ya know it after all night both injectors popped right in no prob! A small amount of grease...
Thanks for the input man.
Old 11-16-2007, 12:39 PM   #4
wbacon
1988 XJ Cherokee
Thats what your suppose to do...use grease..lol
1988 Cherokee 2Dr, 4WD, 4.0 LTR
wbacon is offline   Reply With Quote
Old 11-16-2007, 01:02 PM   #5
alexrule123
I know how you feel, i tried and couldn't get it back in place the first time so I just walked away for a few min and tried it again and it finally popped into place
Glock Forum
