Fuel injector clips? - JeepForum.com
post #1 of 3 Old 05-28-2007, 08:06 PM Thread Starter
Grant-vs-Lee
1994 XJ Cherokee
Hi all! Newbie here.
I'm currently changing my head gasket and I ran into a problem I hope isn't too serious.
While removing the fuel rail I broke or lost most of the tiny metal clips that are between the rail and the injectors. My question is: How important are these clips and if they are vital does anyone know what they're called and where they can be purchased?
Thanks!
Grant-vs-Lee is offline
post #2 of 3 Old 05-28-2007, 09:27 PM
curtjames37
curtjames37's Avatar
Junkyard would probably be the easiest/cheapest place to get them. You might be able to get by without them if it doesn't leak. I wouldn't take the chance though. It would suck if one started leaking and started a fire.
curtjames37 is offline
post #3 of 3 Old 05-29-2007, 01:37 AM
88_xj_hunter
1988 XJ Cherokee
They are called "injector retaining clips" and they are mildly important. If the rail and injectors are already in place, then they don't do much. But they do keep the rail and injectors as an integral unit for installation or removal. Thats important when you are trying to "pop"all of the orings into place. Make sure you use plenty of vaseline on both ends of the injectors when installing. Pick up those clips at the stealership or the junkyard and you can put them on without removing the rail again. But ultimately, its the 3 bolts on the rail that hold it in place and the orings make the seal, not the clips.
'89 XJ Laredo 4.0L, AW4, NP242, Dana 30, 35 w/Lock Right, 5.5" lift, 35x12.50x15 Uniroyal m/t
'88 XJ 4.0L, AW4, NP231, Dana 30, 35 w/Lock Right, 4.5" lift, 31x9.50 SuperSwamper on salvaged 15x7's
'87 XJ Pioneer 4.0L, AW4, NP231, Dana 30, 35 w/ trac-loc, currently stock, 8" lift one piece at a time
Originally Posted by mdonohu1
i sweat your nuts. badly.
88_xj_hunter is offline
fuel injector? skip11and1 XJ Cherokee Technical Forum 3 05-27-2009 09:36 AM
ECU/ECM Fuel Injector Help LokiCDXX XJ Cherokee Technical Forum 0 11-10-2008 04:50 PM
Fuel Injector Problems ruff88xj XJ Cherokee Technical Forum 4 06-05-2008 01:30 AM
fuel injector/fuel rail question LeeBee XJ Cherokee Technical Forum 4 11-16-2007 01:02 PM
Bad Fuel Injector Aqua436 XJ Cherokee Technical Forum 3 11-06-2005 02:06 PM
