fuel injector? - JeepForum.com
post #1 of 4 Old 05-27-2009, 07:22 AM Thread Starter
skip11and1
2013 MK Patriot
fuel injector?
on my 00 XJ when the engine is warm and i got to restart it there it is a rought idle until the engine is running for a few minutes then it goes away. i thought it was a fuel injector so i brought it to a jeep dealer since im stuck down in SC until i get this figured out and they said tht the sleeve on the fuel injector is not working properly and without having to diagnose the entire engine tht is the cheapest thing to change to see if tht does it? does this sound correct?
skip11and1 is offline
post #2 of 4 Old 05-27-2009, 07:40 AM Thread Starter
skip11and1
2013 MK Patriot
i thought i t was vapor lock but the check engine light keps coming on...im stuck with a 95 15 minutes diganostic charge on top of it...ne one wanna shead ne light on the subject?
post #3 of 4 Old 05-27-2009, 08:20 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
What CEL codes are stored ?
The check valve on the fuel pump is prone to failure, leading to a rapid drop in fuel pressure in the fuel rail. With modern oxygenated fuel and the high under-hood temps the Cherokee is known for, vapor lock can happen quickly in the fuel rail. Until the fuel rail refills with cool liquid gasoline, the engine will run rough and possibly misfire. The misfires can generate P0300 series CEL codes. 300 series codes are not fatal and as long as the engine runs properly and you gas MPG is the same as before I would not worry a great deal.
Clean the IAC and TB, add a can of Techron or SeaFoam injector cleaner in the next 2 gas tank fill ups.
CJ7-Tim is offline
post #4 of 4 Old 05-27-2009, 08:36 AM Thread Starter
skip11and1
2013 MK Patriot
im already stuck with the diagnostic charge and he said that the sleeve was malfunctioning and the check engine light keeps comin on i dont know the code number but it said cylinder three misfire..should i jus get it fixed he said it would be like 115 total with the diag. charge so i mines well i guess?
ECU/ECM Fuel Injector Help LokiCDXX XJ Cherokee Technical Forum 0 11-10-2008 03:50 PM
fuel injector/fuel rail question LeeBee XJ Cherokee Technical Forum 4 11-16-2007 12:02 PM
Bad Fuel Injector Aqua436 XJ Cherokee Technical Forum 3 11-06-2005 01:06 PM
Injector Spraying Fuel Everywhere... Help!!! canadianmudinus XJ Cherokee Technical Forum 2 02-26-2005 05:58 AM
Fuel Injector Died wipedawg XJ Cherokee Technical Forum 1 04-26-2004 02:19 PM
