Fuel gauge problem - JeepForum.com
post #1 of 3 Old 11-16-2010, 02:27 PM Thread Starter
Goinbigger
1997 XJ Cherokee
Fuel gauge problem
I just picked up this 97 Sport a little over a week ago with 103k miles on it. The Gas gauge will read normal, but then will just jump to empty for a little bit, and then go back to normal. Back and forth the whole time you are driving. Seems to do it more when you hit a bump. It seems to be a bad ground or something. But it can't be the ground for the sending unit or it would shut the fuel pump off. I jiggled everything I could get my hands on behind the dash but can't see anything loose.
Any ideas where it might be?
Goinbigger is offline
post #2 of 3 Old 11-16-2010, 02:40 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
A loose wire at the gas tank or a bad fuel level sender.
CJ7-Tim is offline
post #3 of 3 Old 11-16-2010, 02:47 PM Thread Starter
Goinbigger
1997 XJ Cherokee
I looked for a loose wire under there, but there are 4 wires coming out of the tank, all go to a plug and then on into the cab. I'm guessing it may be the tank recall, but I have no way to know if mine is one of them that falls under the recall. Guess I will have to call a dealer and find out. I was hoping that maybe there was an actual ground near the tank that had come loose.
problem with fuel gauge. im stumped hypersniper2010 XJ Cherokee Technical Forum 0 10-24-2010 06:56 AM
Fuel / Gas Gauge Problem-Help! Konz XJ Cherokee Technical Forum 2 10-07-2009 06:54 PM
98 XJ Fuel Gauge Problem Agent 000 XJ Cherokee Technical Forum 0 08-18-2008 06:26 PM
Fuel Gauge Problem ranchman XJ Cherokee Technical Forum 15 07-17-2005 07:07 AM
Fuel Gauge Problem 88XJ Ltd XJ Cherokee Technical Forum 3 08-23-2004 07:53 PM
