Fuel filter / pump replacement for 97's and up! - Page 5 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > Fuel filter / pump replacement for 97's and up!
JKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 02-08-2011, 08:53 PM   #61
Haus_XJ
FYI,, Just received email back from Mike Zaher, FUEL PUMP KING..
They are on vacation until March 13, 2011.
Just enough time to figure out what all I'm suppose to buy and replace
Haus_XJ is offline   Reply With Quote Quick reply to this message
Unread 02-08-2011, 09:02 PM   #62
GottaBeJeep
I get my stuff at Autozone now that it is available. Once upon a time these things were considered irreplaceable, but if your pump still works and just want to change the "filters", there are two and you just search for "strainers" on Autozone.com and you will find them. There are two different ones, and will cost you about $15-20 total.
GottaBeJeep is offline   Reply With Quote Quick reply to this message
Unread 02-08-2011, 09:06 PM   #63
Haus_XJ
^ Thanks! I see part # FS220 and FS221. I need both?
Edit - Yes.. I do.
Unread 02-08-2011, 09:13 PM   #64
GottaBeJeep
Edit - Yes.. I do.
you got it. Prices went up a little, but still $25 isn't bad for both.
Rock Lizard Fabrications
...Off Road Armor that's "Tough as Scales"
Unread 05-01-2011, 12:08 AM   #65
botakbeng
Great detailed write-up!
Thx !
Won't have done it without this.
botakbeng is offline   Reply With Quote Quick reply to this message
Unread 05-01-2011, 12:26 AM   #66
predawn
great writeup. did this back in January out in my street in 10F, no lift ramps, nada. very fun though i practiced in a junkyard first. many thanks
getting those J-bolt nuts loose was the biggest challenge, definitely wish i had known about kroil or something stronger than PB. bolts were slightly bent sideways once off as they needed brute force strength to move at half turns.
97 oem sender resistance range is 20-270 Ohms, full to empty, respectively.
predawn is offline   Reply With Quote Quick reply to this message
Unread 05-08-2011, 10:10 PM   #67
sicma99ot
im replaceing my fuel pump right now, have been since 3oclock. i put in the new pump, bosch with the filter attached, buttoned it all back up tired to start it and nothing. ive been purging and trying to start it for about 3 hours now. the most i get is about 2-3 seconds of it shuddering and then dying. i checked the fuel rail and had no pressure at all.
so i broke down and took it all apart again. i put the OLD fuel pump back in and after about 5 minute of priming and trying to start, it firedup! very rough and hesitant start, but it started none the less. also had white smoke comming out the exhaust, but this could be from dipping my dirty hands in the gas right?
anyway, is the NEW fuel pump toast? should i get a replacement? i just dont know why a new pump wouldnt start...
ideas anyone, because im about to set my jeep on fire
98 XJ 4x2 to 4x4 converted
sicma99ot is offline   Reply With Quote Quick reply to this message
Unread 05-08-2011, 11:01 PM   #68
the_weirdo
Take your new pump, put it in a bucket of gas, and apply 12V and ground to it. It should be easy to tell if it pumps gas or not. If the fuel pump is still in the tank, you should be able to remove the Schrader valve from the fuel rail and do the same test when you turn the ignition key to "on".
the_weirdo is offline   Reply With Quote Quick reply to this message
Unread 05-08-2011, 11:08 PM   #69
sicma99ot
yea i did the valve test, there was no pressure at all.
Unread 05-08-2011, 11:17 PM   #70
the_weirdo
If you know that you were getting 12V and ground to the pump, then it sounds like the pump is bad. Try another. You should be able to get a cup of gas pretty easily from the fuel rail.
Unread 05-08-2011, 11:28 PM   #71
sicma99ot
i know that when i put in the new pump, i can hear it prime when the key is on, but no matter how long i try it wont start. i know with that the old pump it will start after 5 min of priming upon first installing and start on 1st or 2nd try there after. the only thing i can figure is either its a faulty pump, or i burnt it up after trying to start it off and on for ~3 hours. when i pulled the new pump out the first time, it was pretty warm. i can also shake the new pump and hear the fuel inside sloshing around. not sure if the gas is suppose to come out or not but nothing comes out.
im ganna go up tomorrow and get another pump and some clean gas. if that doesnt work i might just get a sh*tty airtex assembly.
Unread 07-07-2011, 03:54 PM   #72
RacerX
1989 XJ Cherokee
Does anyone have this info or at least know where the fuel filter is on a 1989 ???
Pics would be nice
4-wheeling is about going where others can't won't or don't think it's safe.
Freedom. Exploring the wilderness, or nature, whatever... - NOT paying to go on someone's roller-coaster ride, or go-cart track!
"The price of freedom is eternal vigilance." - Thomas Jefferson
RacerX is offline   Reply With Quote Quick reply to this message
Unread 07-07-2011, 06:09 PM   #73
JoBo
Pics would be nice
As I recall my 89's filter was under the jeep somewhere and definetly not in the tank
[B]JoBo[/B]
Columbus, Ohio USA
2006 KJ CRD [COLOR="Blue"]Atlantic Blue Pearl Coat[/COLOR][COLOR="Black"] Limited[/COLOR]
2000 Cherokee Classic with factory 16" wheels
JoBo is offline   Reply With Quote Quick reply to this message
Unread 07-08-2011, 12:37 AM   #74
RacerX
1989 XJ Cherokee
great, thanks.
Anyone know where?
I can just crawl under and look around
Unread 07-08-2011, 10:05 AM   #75
gregmondro
You forgot to spray off the bottom of the Jeep first so that you didn't get sand/dirt in your eyes every 5 seconds )
Never fails when I've had to do a pump replacement on one of my Jeeps. All the sand I thought I sprayed off weeks before some how ends up in my eyes.
99 Jeep XJ - NP231, SYE, 4.56's, Rear D44 w/ Detroit SoftLocker and a RockCrusher Diff Cover, 35x12.5 BFG A/Ts, RE 5.5" XD Lift, Skidrow TC Skid, ORT Rear Bumper + Carrier, Rigidco Front Winch Bumper + Steering Box Plate, Milemarker 8000 Winch, Rock Sliders, HD Currie Steering, Control Arm Skids, Goferit Tie Rod Flip Insert, Optima Red Top and a few other goodies...
FiveZeroFive
XJ 8.25 Rear End Disc Brake Conversion For Sale!
gregmondro is offline   Reply With Quote Quick reply to this message
