Fuel filter / pump replacement for 97's and up! - Page 4 - JeepForum.com
post #46 of 101 Old 03-05-2009, 02:05 AM
Jonny Jeep
Jonny Jeep's Avatar
Originally Posted by 99WhiteXJ View Post
Anyone know what spanner wrench he is talking about?
This thing. Most people just use a hammer and big flat screw driver or piece of flat bar, hitting at different points aroud the lock ring to loosen it up. It's on there real tight. I damaged one or two of the vanes when doing mine.
Jonny Jeep is online now
post #47 of 101 Old 03-06-2009, 08:55 AM
99WhiteXJ
Yeah I ended up finding that diagram in my FSM. My lockring was only on handtight so I didnt even need a tool to get it off. It says to tighten to 55 lb/fts (in/lbs? -will have to check on that), any good way to do that without that special tool?
99WhiteXJ is offline
post #48 of 101 Old 03-06-2009, 02:18 PM
Jon08JK
Man this is an old thread and the pictures still work, awesome job to the OP for keeping the pictures hosting current.
2008 Sahara Auto 2 Door 20,450 miles JKUR Coils and shocks, Magnaflow, Superchip, Banks CAI, Winch, OBA and 4:88's
Jon08JK is offline
post #49 of 101 Old 03-07-2009, 05:39 AM
Jonny Jeep
Jonny Jeep's Avatar
I just used the same flat steel and hammer I used to get it off. Just kept going till I thought it was about as tight as when I'd started.
post #50 of 101 Old 03-23-2009, 04:14 PM
90eight
I need to do this same repair soon, thanks for a great write-up.
I have a 98, would anyone happen to know the Carter part number? Rock Auto lists the pump and strainers as part # P74186. I only mention Carter because I can buy them at work.
ΜΟΛΩΝ ΛΑΒΕ
90eight is offline
post #51 of 101 Old 03-24-2009, 02:33 PM
Jonny Jeep
Jonny Jeep's Avatar
I believe that is the carter number. I just googled "carter p74186" and it comes up with that set on different sites including amazon.
post #52 of 101 Old 12-07-2009, 12:47 PM
Fir3Chi3f
1987 XJ Cherokee
It takes a real man to do this in the snow
Nice write up
Fun needs a full tank of gas
My headlining
Fir3Chi3f is offline
post #53 of 101 Old 12-21-2009, 01:44 PM
NORCALROOTS
Hey folks,
I ended up purchasing a float arm sensor separately on eBay to try and save some money on buying the whole fuel sending unit. Unfortunately, after replacing the pump, filter, and float arm, I'm still receiving a bad a fuel level reading. Talk about annoying. My guess is that the float arm I purchased wasn't for the 19 gallon tank I have despite being assured by the seller that it would work. At this point, I'm just living with the bad reading because I don't feel like pulling the tank again. If anyone knows of any simple fixes that don't involve lowering the fuel tank, I'm all ears.
Brian in San Francisco
NORCALROOTS is offline
post #54 of 101 Old 09-11-2010, 08:14 PM
CDog
I know this is an old thread, but still great. My 98 XJ got a new pump this afternoon. The pictures and tips here were great!
CDog is offline
post #55 of 101 Old 10-28-2010, 10:27 AM
Agent11br
This thread was EXTREMELY HELPFUL!!! Many thanks to the OP!
Agent11br is offline
post #56 of 101 Old 11-27-2010, 07:51 AM
jsmiddleton4
1997 XJ Cherokee
I did this due to faulty fuel gauge sending unit. Figured if sending unit piece going bad the pump is also getting worn out. Pump and filter were nasty. That old gas tank fine dirt crap was quite prevalent. Replaced with OEM/Bosch unit. Pricey but they seem to be the longest running pump assemblies. Not wanting to do this again in a few years. So far my fuel gauge is ok. I need to run a few tanks through to make sure.
Actual fuel pump exchange had only one issue. Trying to get the big nut back on and not cross threaded. That was way more difficult than it needed to be.
But here's a secret. Get the button style j- bolts before you start. Mine so rusted each broke when trying to remove their nut. Then it was a real pain to try and find them. Dealer wanted 27 bucks each bolt. I used hook bolts and a bolt extender to grab the heat shield piece. Very secure. Will look for the right button style hook bolts though.
jsmiddleton4 is offline
post #57 of 101 Old 11-29-2010, 09:15 AM
Agent11br
I couldn't agree more, what a PITA
I DEFINITELY second this. I had to cut one of my bolts that was rust welded on, delayed my at least 30-40 mins. NOTE: these j-bolts are NOT easy to come by! You have to order them and they are about $26. In the great lakes area they were back ordered weeks about a month ago.
post #58 of 101 Old 12-25-2010, 02:42 PM
pgv98
1997 XJ Cherokee
Awsome thread, I am about to tackle this job too.
I have one question, I went with the Bosch from Napa and the strainer looks nothing like the original. Did they give me the wrong one? The pump itself is a direct fit.
Any ideas?
1997 Jeep XJ sport
4x4
150,000+
pgv98 is offline
post #59 of 101 Old 12-25-2010, 03:03 PM
Jonny Jeep
Jonny Jeep's Avatar
There are two strainers used one that sits at the base of the pump within the assembly and another that sits at the base of the assembly. The one in the picture seems to be the second of the two. I know rockauto.com has pictures of the different strainers. Maybe you should get the other one too.
Not sure if it's been linked already or not, but check out the fuel pump repair page at dailydriventj.com which also shows the two types of strainer.
post #60 of 101 Old 12-25-2010, 03:29 PM
pgv98
1997 XJ Cherokee
It looks like I will have to make a run to Adavance and buy two new strainers.
The Bosch pump I bought for a 1997 cherokee looks like it has a 1996 strainer on it.
Hope the airtex strainers will fit on the Bosch (14 and 10 dollars).
1997 Jeep XJ sport
4x4
150,000+
pgv98 is offline
Fuel pump, fuel filter problem possibly...??? shoot2thrill XJ Cherokee Technical Forum 10 10-01-2013 06:59 PM
Possible fuel filter or fuel pump failing? shrek317 XJ Cherokee Technical Forum 2 07-21-2009 04:03 PM
Fuel tank lowering tips, and Ebay fuel pump/filter Q's cmassey_2006 XJ Cherokee Technical Forum 10 03-14-2007 05:16 PM
Fuel filter/pump JeepDoggyDog MJ Comanche Technical Forum 8 04-07-2006 04:36 PM
ADVICE!!! Fuel Filter?Fuel Pump?Coil?HELP! ChaoticBastard XJ Cherokee Technical Forum 20 10-07-2005 05:47 PM
