Fuel filter / pump replacement for 97's and up! - Page 2 - JeepForum.com
post #16 of 101 Old 03-12-2005, 09:37 AM
JoBo
Originally Posted by kcrunchone
i have a 1990 cherokee and i do not have any sound deadening material or a carpet in the rear from the seat back. now i have been hearing this sound and i examined closely and found that the sound is residing in the tank .... the fuel pump is sounding off constantly.... now i ask the question if i am supposed to hear it all the time....i have had an 85 so i am not acustomed to the tank in the pump... if this is normal please let me know so i can stop thinking about it...
kcrunch
Your 90 has a external filter and it may be worth replacing as the pump may be working too hard to get the gas through. Also buy a foot of each size fuel line and clamps when you get the filter because once disturbed, the old hose will leak. Ask how I know. As I recall the fittings on the filter are different sizes, if not get 2 feet of the correct size. The pump does run all the time but normally you shouldn't hear it running with the engine on. There's a large white ceramic resistor on the left front fender that drops the voltake once it's running to less then 12 volts. When starting it getts the full twelve. Make sure you have this resister and has bypassed.
JoBo
JoBo is offline
post #17 of 101 Old 03-12-2005, 03:48 PM
offroadman83
Thank you xj99!!!!! I have been wanting to fix this wonderful problem I have for the 2 years I have had it. I will now do so as soon as I have the cash. Thank you so much and If I ever meet you I owe you a beer and some steak=========Kyle
offroadman83 is online now
post #18 of 101 Old 03-12-2005, 05:41 PM Thread Starter
XJ99
XJ99's Avatar
2006 XK Commander
LOL, right on!
When we do right, no one remembers. When we do wrong, no one forgets.
XJ99 is online now
post #19 of 101 Old 04-08-2005, 01:59 AM
fishinsinsation
i need to do this on my jeep....and had a question for you, my gas guage will stop working at times... but will work again if i turn the jeep off a few times... now i was thinking that my sending unit is going bad, and was wondering how much i could expect to pay for this part, and if i would be better off ordering the whole thing from the stealership for the 350 bucks?...
id much rather buy them off that guy on ebay... but probably need the sending unit also.. hmm
..98 limited all options
.................115k POS with monthly electrical/mechanical problems, on the search for another with low miles.
fishinsinsation is offline
post #20 of 101 Old 04-08-2005, 07:58 AM Thread Starter
XJ99
XJ99's Avatar
2006 XK Commander
I would e-mail Mike on Ebay.. He had the whole modules as well.. Someone said he was headed out of town for a while, I'm not sure for how long..
XJ99 is online now
post #21 of 101 Old 10-04-2005, 11:44 AM
DanoTheGuru
how do you get the fill and vent hoses off to drop the tank, do they just pull off the back of the fill port?
'99 XJ
want to sell it! found I dont need 4wd and I'd rather something sportier and smaller, with at most half the engine.
DanoTheGuru is offline
post #22 of 101 Old 10-04-2005, 12:04 PM Thread Starter
XJ99
XJ99's Avatar
2006 XK Commander
Yes. Take the hose clamps off.. Remove the fill and vent hose off of the fill port. The hoses will slide through the frame when you drop the tank. I'd stuff a shop rag in each one to keep the dirt and stuff out of them..
XJ99 is online now
post #23 of 101 Old 03-31-2006, 03:05 PM
CarlosH
i have the same problem with my xj i was checking the autozone page looking for the filters and what they have FUEL PUMP STRAINERS and it said it requires two when you replace the pump is the same as filters
CarlosH is offline
post #24 of 101 Old 03-31-2006, 04:02 PM Thread Starter
XJ99
XJ99's Avatar
2006 XK Commander
Strainers, filters, socks yes there are 2.
XJ99 is online now
post #25 of 101 Old 05-14-2006, 11:18 AM
oldbastard
Well I did the pump and filter replacement yesterday. Thank you for the guide because I could not have done it without it.
After I got it all back together and put some fuel in the Jeep is pretty much started right up. I got to admit I was a little afraid of the boom factor when I turned the key. I don't know much about working on vehicles but is the whole idea of a fuel pump with 12V inside the gas tank really such a good idea? Are all vehicles like this? Is the electrical connector connected to the float 12V? Or is the 12V only on the inside of the housing? If gas ever gets inside the housing are you driving a gas bomb?
oldbastard is offline
post #26 of 101 Old 05-14-2006, 01:07 PM
AZ Jeff
2014 JK Wrangler
Electrical connections inside a gas tank are not a hazard. Here's why:
There is no potential for explosion because the amount of oxygen available in a gas tank is almost nil when full (12V immersed in a lake of gasoline has no oxygen to ignite anything.)
When the tank is empty (or nearly so), the vapors in the tank are almost all gas vapors, with again, very little oxygen. No O2 means no combustion.
The only time gasoline is dangerous is when it has oxygen in the correct proportions to be combustible.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #27 of 101 Old 09-05-2006, 08:29 PM
88wrangyj
Originally Posted by XJ99
Remove the evap, and regulator hoses. The evap hose is just rubber that slides over a nipple and the regulator hose has a quick disconnect fitting. Just squeeze the plastic clips in and the fuel line will pop off. (do this holding a rag over it so gas doen't squirt everywhere) Then just unplug the the wire harness going to the tank. (you have to slide the red clip over to do this)
Very informative write up, I will be doing my fuel pump this weekend. The only thing I thought of when reading this was relieving fule pressure. If before you start you pull the fuel pump relay and let the jeep run until it dies there should be no pressure in the lines which mean its won't spray all over. Gas in the eye is not a fun feeling.
88wrangyj is offline
post #28 of 101 Old 09-06-2006, 10:08 AM Thread Starter
XJ99
XJ99's Avatar
2006 XK Commander
Good tip!
Also a spanner wrench would be good to have for taking the pump module off:
XJ99 is online now
post #29 of 101 Old 10-04-2006, 07:58 AM
CartsXJ
PART: III
Slide the little pipe off the old pump and put it on the new one. Then remove the cork piece off the old pump and carefully place it on the new one.
Ok now you can put the new pump with filter back in...
Remeber those washers! First put the orange rubber one in, then the metal one in. Then the new pump goes on top of them. (the filter on the pump should kinda snap into place) Make sure the new pump is seated correctly.
Put the spring back on the pump.
Make sure the pump is plugged in.
Slip the top half of the module back on making sure the metal tube fits into place.
The spring will push against the pump keeping it from coming back out.
Wa la, the hard part is done!
Now you wnat to change the pick up filter (AKA the sock)
Just gently pry up on the old filter and it will pop off..
The old filter: (nice!)
The new filter: (sweet!) hehehe
Pop the new filter / sock into place:
Congratulations, you just rebuilt a fuel pump module!
Are these strainers/filters something they changed in 99, I just got a new assembly for my 98 and I didn't see anything like that on the bottom. And they don't list it for on any dealer parts list. The dealer mentions for my 98 that the filter is part of the regulator.
CartsXJ is offline
post #30 of 101 Old 10-04-2006, 10:58 AM Thread Starter
XJ99
XJ99's Avatar
2006 XK Commander
From what I understand, they should be the same from 97 on up.
May be your sock/filter fell off??
XJ99 is online now
Fuel pump, fuel filter problem possibly...??? shoot2thrill XJ Cherokee Technical Forum 10 10-01-2013 07:59 PM
Possible fuel filter or fuel pump failing? shrek317 XJ Cherokee Technical Forum 2 07-21-2009 05:03 PM
Fuel tank lowering tips, and Ebay fuel pump/filter Q's cmassey_2006 XJ Cherokee Technical Forum 10 03-14-2007 06:16 PM
Fuel filter/pump JeepDoggyDog MJ Comanche Technical Forum 8 04-07-2006 05:36 PM
ADVICE!!! Fuel Filter?Fuel Pump?Coil?HELP! ChaoticBastard XJ Cherokee Technical Forum 20 10-07-2005 06:47 PM
