front windshield wipers not working - JeepForum.com
post #1 of 19 Old 02-15-2009, 06:32 PM Thread Starter
USMC_XJ
2003 WJ
just stopped working. worked last night, got in today and now they dont work. checked all fuses and all good. checked wiring at wiper motor and it was still attached. are there any other fuses i can look at or relays? the rear wiper and washer still work. the washer does not work for the front, which leads me to believe that it is a wiring problem. any ideas on what it could be? i have to drive 3 hrs tomorrow so i need to get it fixed asap.
thanks in advanced
1994 Cherokee Sport - 4.0 HO - AW4 - 4WD
Originally Posted by Rob99
The next time you want to tell a story but not get people's opinions, rather than post it on an internet forum, open up Microsoft Word, type your story there, then click on the little X in the top right corner and then hit yourself in the head with a sledge hammer.
Originally Posted by bigsquat
If he finds the yj section im putting round headlights on mine.
USMC_XJ is offline
post #2 of 19 Old 02-15-2009, 06:35 PM
lurkeryj
1997 XJ Cherokee
possibly a multi function switch failure
lurkeryj is offline
post #3 of 19 Old 02-15-2009, 06:45 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
I believe there is a relay, in the pdc beside the battery.
xjfever is offline
post #4 of 19 Old 02-15-2009, 07:08 PM Thread Starter
USMC_XJ
2003 WJ
there is no relay labelled wiper switch or anything in the pdc. is the multi function switch the wiper switch?
USMC_XJ is offline
post #5 of 19 Old 02-15-2009, 07:22 PM
filluptrk
There is circuit breaker in space #30 in the junction block. This is in the FSM for my 00, your 94 may be the same. If you have an VOM you can check the breaker. If it is good, then you can check for voltage on the pins of space #30. If none there is a good chance your wiper switch is bad. Phil
filluptrk is offline
post #6 of 19 Old 02-15-2009, 09:46 PM Thread Starter
USMC_XJ
2003 WJ
well. i dont have a multimeter as of right now, (3 hrs away). idk if this helps but, i have a wierd cruise control integrated with the wiper switch. so my brights work, blinkers work, cruise control works. the only thing that doesnt is the wipers. could the switch fail with the wipers and still work with everything else? i checked the intermittent thing and the connects are good, (the one that is under the dash. i will check to see if i have anything in the pdc has anything to do with the wipers. i dont have a junction block, i think that they changed it in 97'
any ideas on anything else?
USMC_XJ is offline
post #7 of 19 Old 02-15-2009, 09:56 PM
Parky
Parky's Avatar
The intermittent module under the dash is usually the culprit. There is usually a short in the circuit board (you may not be able to see it) which then causes the circuit breaker to blow. I went to the dealer to get a replacement and it was back ordered indefinitely and have not found them anywhere else. I thing the supplier quit making them.
So to get around the circuit breaker always blowing I just got a wire and jumped the circuit where the breaker was. The intermittent settings don't work, but at least I can turn on the wipers.
Colorado Jeep Member #12
Happy Jeeper
Parky is offline
post #8 of 19 Old 02-15-2009, 09:58 PM Thread Starter
USMC_XJ
2003 WJ
well i thought that it could've been the intermittent thing, but i unplugged both sides and bypassed the whole thing, and the wipers still don't work.
USMC_XJ is offline
post #9 of 19 Old 02-15-2009, 10:13 PM Thread Starter
USMC_XJ
2003 WJ
just went out right now. the 7.5A fuse is good. nothing i could find in the pdc in the engine compartment by the battery. i have no voltmeter or test light.
so i assume that it is either the wiper switch it self or the wiper motor? but since its also the wiper washer motor that isnt working, i assume that it must be the switch. ugh this is sooo aggrivating. now it is starting to snow realllly bad. if i put the wiper in the high/fast position and pull the fuses in and out, should it spark or anything?
USMC_XJ is offline
post #10 of 19 Old 02-15-2009, 10:13 PM
Parky
Parky's Avatar
Try jumping the circuit breaker and see if that works.
Happy Jeeper
Parky is offline
post #11 of 19 Old 02-15-2009, 10:28 PM Thread Starter
USMC_XJ
2003 WJ
so i went outside to try to figure it out and stuff and accidentally hit this:
it fell off the bottom of the fuse block. is this the "breaker" that every one is talking about?
when i hit it, the wipers started working
USMC_XJ is offline
post #12 of 19 Old 02-15-2009, 10:32 PM
filluptrk
I think the answer is YES. Phil
post #13 of 19 Old 02-15-2009, 10:41 PM Thread Starter
USMC_XJ
2003 WJ
hahaha..... ok.
thanks a lot fellas.
USMC_XJ is offline
post #14 of 19 Old 11-10-2009, 09:05 PM
sickness
Junior Member
1994 XJ Cherokee
bump
alright i just had a similar issue crop up. i checked all the fuses they are all n good shape. how ever the fuse in the slot for the wipes does not read and the radio stopped working too at the same time. i was using the wipers and radio just an hour prior to them noti had to drive home in the dumping down rain. Thank god for rain-x any way i am pretty sure it is a wiring issue. (what would cause the power to not go to the fuse like that out of the blue.?) Please help me winter is comin.
sickness is offline
post #15 of 19 Old 12-02-2009, 07:00 PM
Rubicon304
Has anybody found a place to buy the circuit board? I just broke mine as I was pulling out the buzzer thing. I have been to every auto parts store in town and they don't have/can't get it. I went to the dealer and they can't get it either! I tried the junk yard too but they only had a handful of XJ's and the only one that had one was rusted and broke as I tried to pull it out.
96' XJ Sport. Stock but fighting me to being a real Jeep.. one rusty part at a time...
Rubicon304 is offline
2000 XJ front windshield wipers jumping TJSport98 XJ Cherokee Technical Forum 1 09-13-2009 02:44 PM
95 xj windshield wipers not working....HELP!!! XJ98beast XJ Cherokee Technical Forum 1 08-21-2009 08:48 PM
windshield wipers not working Justin1805 XJ Cherokee Technical Forum 1 03-14-2009 06:31 PM
Windshield Wipers Not Working pgdyk XJ Cherokee Technical Forum 6 12-26-2007 09:13 AM
Windshield wipers suddenly stopped working...help!? White-Knight XJ Cherokee Technical Forum 4 02-12-2003 07:37 PM
