Front Wheel Problem - JeepForum.com
post #1 of 5 Old 10-13-2009, 04:02 PM Thread Starter
monkeymom
1997 XJ Cherokee
Front Wheel Problem
My 97 4.0 has a new problem today. could use some help. When in drive the right front wheel is making a clunking noise kinda like if you had a flat tire with out the bumping. I jacked it up and the tire is hard to move with your hands. It didn't do it when in reverse. Any ideas?
Thanks
monkeymom is offline
post #2 of 5 Old 10-13-2009, 04:19 PM
Jenner
peolpe are going to ask you more about your jeep before diagnosing. Is it all stock? Ton of miles on it? Anything in the area been recently replaced?
1998 Jeep Wrangler SE
Project.
Mods so far...none
Maintenance to keep it on the road...Oh my god.
Jenner is offline
post #3 of 5 Old 10-13-2009, 04:27 PM Thread Starter
monkeymom
1997 XJ Cherokee
Mileage is 140,000. Stock. I just had the flywheel replace, radiator, and the rear end about 3 months ago.
post #4 of 5 Old 10-13-2009, 04:40 PM
Jenner
With the wheel off the ground, grab it and shake it. Is there any play? The hub bearing might be toast. Also stick a couple fingers on the axle u-joint and wiggle it hard. shouldn't be any play there either. Inspect the bushings in you sway bar. they can cause a nasty thump if they are trashed. Although that wouldn't affect the wheel not spinning. Is the brake seized up? Might be you're unlucky and its a combination of things.
Project.
Mods so far...none
Jenner is offline
post #5 of 5 Old 10-13-2009, 05:27 PM
Luke94XJ
1994 XJ Cherokee
sounds like the hub is bad.
Luke94XJ is offline
1999 Limited front wheel hub problem dodge55 XJ Cherokee Technical Forum 9 11-30-2009 12:41 PM
4 wheel drive front wheel lock up HELP! rokiskim123 XJ Cherokee Technical Forum 6 05-09-2009 08:25 AM
Replaced front brake pads, now smoke coming from front wheel....help? caspergotaz28 XJ Cherokee Technical Forum 17 05-01-2005 03:03 PM
Front wheel problem Gorf XJ Cherokee Technical Forum 2 02-25-2005 07:14 PM
4 Wheel to 2 Wheel problem patrickjeep XJ Cherokee Technical Forum 3 06-10-2004 07:53 PM
