Quantcast Front Wheel Bearings - JeepForum.com
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Front Wheel Bearings
Old 01-05-2007, 09:35 PM   #1
XJChris98
Alright, well after two days of poking around at my front axle to figure out what was making so much noise, im almost 100% sure its the hub bearings. So now that ive figure all this out, heres my question. How much should I expect to pay to have the hub bearings repacked? ...Or should I just do it myself?
XJChris98 is offline   Reply With Quote
Old 01-05-2007, 09:40 PM   #2
mortalenema
Drivin' me nuts...
mortalenema's Avatar
I think they are a complete assembly. They can't be repacked. They are around $150-$170 each.
'99 Classic: "Emma"
8.25 * NP242 * Auto trans * 3" OME HD lift * IPF lenses and H4s * Uniden PC78elite
JKS Discos and adjustable track bar * 31" BFG T/A KOs on 15x8 black Cragar soft 8s
Tom Wood's SYE and custom drive shaft * Custom evil shark mouth skid plate * Hingeless 2-way hood vents
Jeeps with Teeth #1
MN Jeeper #14
_____________________________________________
"When is the best time to do things? Who is the most important one? What is the right thing to do?"
"BORN TO WHEEL" PRODUCTS FOR SALE
**********More designs here**********
mortalenema is offline   Reply With Quote
Old 01-05-2007, 09:41 PM   #3
ChairKey00
If I'm not mistaken, the 98 model Jeeps don;t have seperate wheel bearings. They have an entire hub assembly that must be replaced. Probably set you back between $100-$140 new at Autozone.
2000 Jeep Cherokee Classic
2006 Kawasaki ZX-10R
2002 Honda Accord SE - Hers
2001 Nissan Maxima SE 20th Anniv. 5sp
2006 Pontiac GTO 6sp (12,500 miles)
1992 Chevrolet S-10 (224,300 miles...all original)
ChairKey00 is offline   Reply With Quote
Old 01-05-2007, 09:49 PM   #4
Powellae
If you have basic tools and a torque wrench, you can do this. there are writeups on the web. It's about a 90-minute job per side.
Powellae is offline   Reply With Quote
Old 01-05-2007, 09:50 PM   #5
midfat
I have a 99 and, yes, they are a complete hub assembly. I picked up new bearings for $121 each from my local auto parts store. If you do it yourself, you'll also need a 36mm axel nut and an 11mm 12-point socket (Very important it's a 12 point socket as the bolts are 12 point bolts!)
For me, it was not a difficult job. Many complain of trouble pulling the bearing out of the steering knuckle assembly, but with a three arm gear pullert, it was a piece of cake.
midfat is offline   Reply With Quote
Old 01-05-2007, 10:02 PM   #6
XJChris98
I wasnt sure if they could be repacked or not, but thanks for clearing that up guys! Theres a guy in our local club that found a place that sells the entire assembly for 65$. Thats deff cheaper than what the local auto parts store wants for them, but still more than what I was hoping to have to spend right now. Dang your Christmas!!!
Old 01-05-2007, 10:04 PM   #7
Powellae
Midfat has it right. A 12-point socket is nothing special, it's just a socket with 2x the number of contact points as a 6-point socket.
Have some penetrating oil handy to help get the rotor off once the caliper is out of the way. It may stick to the hub. I ended up soaking it for an hour, then putting a 2x4 behind the edge of the rotor and whacking it with a hammer to get it to move. Once it started, I just rotated the rotor and tapped it (using the 2x4 as a pad) in various places until it came loose.
Glock Forum
