Front wheel bearing symptoms? - JeepForum.com
post #1 of 16 Old 02-05-2009, 07:28 PM Thread Starter
AbsolutXJ
1953 M-38
Just picked a 97 4dr with 153k miles on it. I can hear a faint scraping noise from the front left wheel. It seems to speed up or slow down with the speed of the wheel. I'm assuming that this is a wheel bearing/hub issue. How big of a deal is this to replace? Additionally, I have a oil pressure gauge that reads zero constantly although I seem to be getting actual pressure as the motor runs smooth. Sensor? Sending unit? The last problem that I've found is that the blinker refuses to cut off after the wheel is straightened back out. Not a hug deal but it's slightly annoying. Any thoughts would be great.
1979 CJ-7
1978 CJ-5 (Wrecked Awaiting Rebuild)
Willys M38A1 - project vehicle
AbsolutXJ is offline
post #2 of 16 Old 02-05-2009, 07:32 PM
mountainpoo
1994 XJ Cherokee
if you can get the jeep on jack stands, then hold the tire at 12 and 6 o clock and if there is any play the wheel bearing is most likely bad.(assuming the tire is on tight).
i would change the oil pressure sending unit and if that doesnt work i would the its the guage itself?
1994 xj
RE 3.5 superflex/RE adjustable track bar
DT3000 shocks
cragar soft 8's 4" BS
31x10.5 R15 cooper discoverer stt's
homemade snorkel
mountainpoo is offline
post #3 of 16 Old 02-05-2009, 07:40 PM
Lynch_6913
well with the blinker its jsut a little catch and its inside the steerin column, i've yet to dig into that yet though. but the wheel bearring is vairly simple i jsut replaced mine. ya put in up on jacks tae the tire off, remove the brake caliper with what should be 2 torque nuts in back, after that it is 3 bolts on the side twords the engine there are 3 bolts to losten and it should come i believe if i remember right, also its a good time to see if ya need new u joints sinse its already off.
Lynch_6913 is offline
post #4 of 16 Old 02-05-2009, 07:51 PM
theglowingbus
1997 XJ Cherokee
well Ive done the hubs a few times in the past month now. First your going to want to pb blast the hub bolts, and once you get those out, the hub will probably not come out, so the way i did it since i was already replacing hubs and didn't care for them, was to bang on them with a 3 or 5lb sledge. This will eventually get the hubs out, just takes a few good blows. If that doesn't work try a pickle fork, but it will defiantly mess up the backing plate. Also I know there's a way to take of the hub using a 13mm deep socket, but i haven't tried yet. Just search that option. So pretty much it will take you probably an hour or two, depending on how much stuff is rusted in there, Its not that bad though.
Good Luck and have fun
Alex
theglowingbus is offline
post #5 of 16 Old 02-05-2009, 10:29 PM Thread Starter
AbsolutXJ
1953 M-38
Now I guess my next question would be if I do one side should I do the other side?
1979 CJ-7
post #6 of 16 Old 02-05-2009, 10:43 PM
foggybottombob
I have 188K miles on my 91 XJ axle and the wheel bearings have not needed replacing yet. I'm going to change the whole front axle so I guess I'll never replace those D30 unit bearings.
foggybottombob is offline
post #7 of 16 Old 02-06-2009, 12:34 AM
jmitywhitey
1988 MJ Comanche
check the brakes first may be the wear indicator .oil pressure i vote on the sensor .
jmitywhitey is offline
post #8 of 16 Old 02-13-2009, 09:57 PM
theglowingbus
1997 XJ Cherokee
yea, well only one of mine were messed up, but i ended up replacing both, and now it rides a whole lot smoother.
post #9 of 16 Old 02-21-2009, 08:25 AM
robhollar
1992 XJ Cherokee
Raise the jeep up and place on jack stands. Place one hand on your coil spring and spin the wheel with you free hand. You should be able to feel in the spring if you have a bad wheel hub.
robhollar is offline
post #10 of 16 Old 02-21-2009, 09:46 AM
GregB_00XJ
This is how I was told to look for a front wheel bearing issue...
My mechanic said that they put it on a lift all 4 wheels off of the ground. Put it in 4WD High and when up on the lift, start it and have a friend put it in gear. Under very slight acceleration (a friend doing this obviously) you do the spring test. The one with the vibration is the bad one. Too bad that they are not serviceable units... but they are still easily fixed.
Also, sounds like it could be a bad caliper? Pistons not releasing properly?
- 2005 Jeep Grand Cherokee LTD 5.7L WK -
____=__=
l l ,[_____],
l---- L -[]lllllll[]-
()_) ()_)--o-)_)
GregB_00XJ is offline
post #11 of 16 Old 02-21-2009, 11:48 AM
nexus42i
Just did the hub on my left front last week. Job was pretty easy, PB blasted the bolts and used a big breaker bar to get them out and then used a BFH to pound on the hub to free it up.
Also did the u-joint at the same time, plan on doing the u-joint on the passenger side tomorrow, and will probably replace the hub too while I'm at it.
The Jeep rides smoother than I could have ever imagined with the new hub/bearing. It's been worn out since I bought it 20K miles ago.
nexus42i is offline
post #12 of 16 Old 05-19-2009, 07:20 PM
grimah1w
1990 XJ Cherokee
nexus42i,
so you replaced the hub/bearing carrier as a unit...both sides? replaced with tappered bearings included I assume? What was the cost for each side? Anything else to order to get it done?
Thanks!!!
Vince
2008 Overland WK 5.7L Hemi
1990 Cherokee Limited XJ 4.0L Renix -- 3.5" RE and OME, '95XJ Booster+M/C upgrade
grimah1w is offline
post #13 of 16 Old 05-19-2009, 07:37 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
You can't replace the bearing itself, you have to replace the entire hub. They are non-seviceable units. Be sure to get the good ones or they won't last long.
xjfever is offline
post #14 of 16 Old 05-19-2009, 07:39 PM
BunnyHunterOG
You should make sure its not just the dust shield scraping the rotor before you go replacing hubs.
BunnyHunterOG is offline
post #15 of 16 Old 05-19-2009, 07:44 PM
a5tach
yeah, I lowered my front end when I did my lift an now my dust shield rubs really bad. I wedged something in between the rotor and the shield...hopefully it moves back out as it is just sitting there...bunnyhunter is right, check that first, especially if its been lifted or worked on by the PO
a5tach is offline
Symptoms for Front Wheel Bearings (Hub) Replacement... JBassXJ XJ Cherokee Technical Forum 26 07-29-2010 07:30 PM
Front Wheel Bearing CherokeeClassic XJ Cherokee Technical Forum 7 05-12-2009 01:38 PM
Symptoms of a bad wheel bearing? Dannn XJ Cherokee Technical Forum 2 12-16-2008 08:57 AM
Wheel bearing symptoms? themow XJ Cherokee Technical Forum 10 12-09-2008 11:00 AM
Front wheel bearing? lilseth0014 XJ Cherokee Technical Forum 2 09-07-2007 09:03 PM
