Front vibration/grinding when driving - JeepForum.com
post #1 of 9 Old 10-17-2013, 08:37 AM Thread Starter
cpdr26
99 XJ 4.0L - approx 180k
So I was under the impression that my wheel hub bearings were going bad, because when I'm driving I can feel a very faint vibration/grinding kind of feel through the steering wheel. So I replaced them last week, and one of the hubs was pretty bad, and the other one wasn't all that bad.
So today, I'm driving...and I still feel this faint vibration/grinding. What else can this be? It is speed dependent, so I feel it more when going faster. Could this be something as simple as the tires? I have all season tires and they've got about 80% tread left...or can the front diff cause any vibrations?
Thanks for any suggestions
cpdr26 is offline
post #2 of 9 Old 10-17-2013, 08:24 PM
JeepZJlover
I'm in the same boat I'm pretty sure it's carrier bearings
1993 Cherokee 4dr SE green, 4.0, Auto, HP30, 8.25, 3" lift 31" Goodyear Duratracs, Custom made front recovery bumper, Kenwood radio, 12" alpine type e subwoofer,alpine amplifier, Smittybilt xrc8 winch, tuff stuff portable winch receiver custom modified. 2002 Jeep Wrangler Sport 4.0, 5 speed, Dana 30 front, Dana 44 trac loc rear, Stock
JeepZJlover is offline
post #3 of 9 Old 10-21-2013, 04:07 AM
xj89can
1989 XJ Cherokee
id also like to know , im having the same issue. not positive but sounds to be front passenger side on mine. its a rotating grinding sound ,loudest at 40-50km/h .no leaks besides the stock oil drip. freshly greased u joints, diffs are filled, drive shafts clean,nothing loose. sound seems to quiet itself at faster speeds .sorry not trying to jack your thread but it seems we have the same issue so im going to ride your coat tails on this one. thks in advance
xj89can is offline
post #4 of 9 Old 10-21-2013, 07:00 AM
fang_x
Check your front driveshaft, my Tj was making a grinding sound, checked the wheel bearings and they were fine.
So i pulled the front shaft out and the double cardon joint was bad. The u joints were fine, but the centering ball was broken.
i had similar symptoms
'98 TJ Manual -2.5" rcx long arm on 31
'99 Xj, Stock on 30"
'86 Monte Carlo 357 stroker. 450hp.
fang_x is offline
post #5 of 9 Old 10-21-2013, 11:30 AM
xj89can
1989 XJ Cherokee
fang x what as the price tag on this ?
thks
xj89can is offline
post #6 of 9 Old 10-21-2013, 02:05 PM
jeepster383
New front driveshaft from parts stores will run 250$. Check you're axle u joints also
jeepster383 is offline
post #7 of 9 Old 10-22-2013, 01:05 AM
carnuck
1984 J-Series Truck
Make sure it's not a bent brake backing plate touching the rotors!
"Usually found in a Jeep near Reiter, WA"
FOR SALE STUFF
'81 Eagle wagon with upgrades $2500
'87 Comanche shortbox 4.0/AW4/NP242 on 33" tires $3500
carnuck is offline
post #8 of 9 Old 10-22-2013, 01:24 AM
kyminer
My 04 is doing the same thing.
kyminer is offline
post #9 of 9 Old 10-22-2013, 01:26 AM
kyminer
Originally Posted by fang_x
Check your front driveshaft, my Tj was making a grinding sound, checked the wheel bearings and they were fine. So i pulled the front shaft out and the double cardon joint was bad. The u joints were fine, but the centering ball was broken. i had similar symptoms
my 04 is doing same thing. I was thinkin diff bearings. But did that fix it. I'd rather replace that vs front end
kyminer is offline
