front track bar - JeepForum.com
post #1 of 4 Old 03-31-2002, 09:09 PM Thread Starter
jayhawk
Question front track bar
Hey everyone,
I just put a 3" Skyjacker Lift on my '93 XJ Sport. I am more than pleased with the added height I gained, but I think there is a weak link in the kit: the front track bar drop bracket. I used Skyjacker's new bracket but my front axle is pulled 1" to the passenger side. (I can tell because my bumper stops are not in the middle of the coil spring). I also heard that these brackets tend to hollow out after awhile. I know that I should get an adjustable track bar, but where is the CHEAPEST place to get one? Any other suggestions on how to fix the problem would also be appreciated. Thanks.
(P.S. for the first time lifters such as myself, do yourself a favor and make your own transfer case drop bars instead of wasting money on manufactered ones)
jayhawk is offline
post #2 of 4 Old 03-31-2002, 10:22 PM
EricsXJ
The Post man
EricsXJ's Avatar
Post
To see if your axle is off center, measure the space between the outside edge of the tire and the flare. I have heard the JKS adjustable track bar is nice if you ever need to replace yours. (BTW, I have the RE adj. track bar)
Eric
2000 XJ "PROJECT RUBICON" 3-link front / 4-link rear / coilovers / running 37's on Dana 60s
My website -
EricsXJ is offline
post #3 of 4 Old 04-01-2002, 06:09 PM
CB89XJ
Post
Rusty's sells one too. Just make sure your bolt is really snug, and it shouldn't hollow or ovalize the hole. I have one of those little brackets too, and haven't had any problems.
Colin Beatty
'87 YJ, built 351W, T-18, NP-205, SOA, SRS, 35x12.50 ProComp MT's, cage, winch, Tomken bumper/carrier, d44/9"
www.bmja.org
CB89XJ is offline
post #4 of 4 Old 04-02-2002, 03:38 PM Thread Starter
jayhawk
Post
Thanks to the two relpies. I decided to take off the bracket and install a new adjustable bar from Skyjacker. Let's hope this is the end of it, for now.
jayhawk is offline
xj front end help-track bar? 1badass4x4 XJ Cherokee Technical Forum 1 08-16-2007 12:19 AM
JKS Front track bar YellowSport XJ Cherokee Technical Forum 4 08-18-2005 12:55 AM
Front track bar YellowSport XJ Cherokee Technical Forum 8 08-09-2005 11:08 AM
Front Track Bar and LCA ?'s latapx5 XJ Cherokee Technical Forum 5 02-15-2005 10:00 AM
Front track bar??? powerman330 XJ Cherokee Technical Forum 16 12-24-2004 12:17 AM
