Front sway bar mount at axel broke off ??? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > XJ Cherokee Technical Forum > Front sway bar mount at axel broke off ???
Rough Country LED BracketsIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineAll Bilstein shocks & struts - Lowest Prices Ever and
Unread 01-26-2011, 12:04 PM   #1
havasu1
Anyone know if there is a company that makes a replacement tab. Basically, the tab that is welded to the axel that the Quick disconnect slides onto broke off? Very strange, but the OE metal tab seemed almost like pop metal. Now I am driving with no front sway bar. Seems odd that the tab would fail before any of the QD components.
havasu1 is offline   Reply With Quote Quick reply to this message
Unread 01-26-2011, 12:20 PM   #2
havasu1
Here is the tab/braket that snapped on the passanger side. I need to grind off what remains of the old one (and maybe the other one on the driverside) and weld on a replacement. Just wondered if a company sold replacement ones that are lazer cut or someting.
Unread 01-26-2011, 12:22 PM   #3
justanotherjpr
These should do it for you
http://store.jksmfg.com/merchant2/me..._Code=FABParts
So do you actually hear your thoughts in your head or is it just sort of a dull roar before you smash your face into your keyboard and just submit whatever dumb **** ended up on the page?
justanotherjpr is offline   Reply With Quote Quick reply to this message
Unread 01-26-2011, 12:56 PM   #4
CJ7-Tim
Real Jeeps have dents.
CJ7-Tim's Avatar
http://www.polyperformance.com/Syner...racket-Weld-On
Total US debt has increased by 70% under Obama, from $10.625 trillion on January 21, 2009 to $18.005 trillion January 1, 2015.
Progressive Liberalism: Bringing you new Healthcare ideas so wonderful, they have to include mandatory participation ......
CJ7-Tim is offline   Reply With Quote Quick reply to this message
Unread 02-21-2012, 05:45 AM   #5
Ibnzmonkey
2002 KJ Liberty
YES! I require these for mine. The HP30 I installed had these cut off.
Ibnzmonkey is offline   Reply With Quote Quick reply to this message
Unread 02-21-2012, 12:25 PM   #6
sAe23
1995 XJ Cherokee
I BENT one of mine
If I can't straighten it out, I'll also be doing this...
sAe23 is offline   Reply With Quote Quick reply to this message
Unread 02-21-2012, 02:10 PM   #7
Azzy
Azzy's Avatar
Originally Posted by sAe23 View Post
I BENT one of mine
Heat and a hammer... one of mine came that way.
Im the guy who makes new gauges, check out our gallery at Teamadw.com
Azzy is offline   Reply With Quote Quick reply to this message
Unread 03-21-2015, 03:24 PM   #8
Kit4fish
Anyone know if there is a company that makes a replacement tab. Basically, the tab that is welded to the axel that the Quick disconnect slides onto broke off? Very strange, but the OE metal tab seemed almost like pop metal. It's the front right mounting bracket that broke.
Kit4fish is offline   Reply With Quote Quick reply to this message
Unread 03-21-2015, 03:26 PM   #9
Kit4fish
Sorry. My Jeep with a 2006 wrangler Golden Eagle.
