#1 | |
front shocks
how do I unistall my front shocks ?
#2 |
nom nom nom
Open your hood and find the upper "bayonet" end of shock. Remove nut. Next remove two bolts at axle end. Remove shock. If I remember correctly, nuts and bolts are 13 or 14mm.
'93 Cherokee Sport 4.0 man. 4.5" Black Diamond/ O.M.E., JKS control arms, discos, track bar, rear D44/detroit, 35x12.5 BFGmt's,33x13.5 LTBs,AlloyUSA shafts, oba, Warn M8000 multi-mount '97 Cherokee Sport 5spd,231, white, stock '90 Cherokee Pioneer 4.0 auto, 6" homebrew long arm lift, 33x10.5 BFG MT's, etc. '87 XJ 2" lift '96 XJ stock "Personally, I've learned so much from my mistakes, I'm thinking of making some more." "Don't believe everything you think..." |
#3 |
Nuts on the upper mount are millimeter sized (14 or 15mm), but at least on mine the lower mounts were ½" or something. The bolts on the axle can be pretty stuck, especially if they are rusted -> use a big wrench and a hammer to remove..
edit: you propably need to remove your airbox on the driver side to gain access to the upper mounts. Easy thing remove 3 nuts + all the hoses. Takes about 5 mins.
1998 Grand Cherokee 5.9 LX, 100k miles, 1.75" BB, 32 x 11.50 BFG MT KM2s, custom- fabbed bumpers etc.. http://www.jeepforum.com/forum/f13/daily-driver-5-9-build-thread-bumpers-tube-rockers-etc-1222317/ 1990 XJ Limited (4-door), 4.0 I6, AW4, NP242, ***rolled and totalled @ 165k miles*** ***Under construction*** 1990 XJ (4-door), 4.0 I6, AW4, NP242, PBR 42" tires, Unimog portal axles, 110" WB, full cage + uniframe completely rebuilt, front 3-link + panhard / double triangulated 4-link rear, etc... http://www.jeepforum.com/forum/f11/hybrid-cage-build-exo-cage-internal-973910/ |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
