Front end Whine/howl. Diff? wheel Bearing? U joint? What could it be? - JeepForum.com
post #1 of 10 Old 06-29-2006, 11:15 AM Thread Starter
Xride
Ok, I have a whine/howl coming from the drivers front of my jeep.
its a constant sound when driving straight, kind of a low howl and kinda quiet, almost mixes with the tire noise.
when accelorating, there is no sound. but there is holding speed, and when coming to a quicker stop kinda.
when turning right, without power, it is very loud, like over power people talking inside loud. but if I use the gas even a little bit turning right then there is no sound.
turning left is quiet.
I have no idea what it is, it is for sure coming from the front driver side.
I had some work done to fix it, but it did not fix it, they claim to have changed the u joint, and the wheel bearing hub assembly, although I am confident they didnt replace these parts.
So what could be causing this? I almost want to say its the diff, but they are factory gears and it has never been opened, the diff fluid looks good and no chunks come out when a rod with a magnet is poked around in there.
I need to get this fixed asap. I am putting 2k km on my jeep this summer going through the rockies, and dont want any problems. not to mention when turning right I feel like cranking it hard and rolling her over just to make the sound stop.
Any help would be great, thanks.
99 XJ, black, 4x4, NP231, 8.25 rear. Fully locked.
5.5" long arm lift, 35x12.5x15 Kumo KL71MT
Xride is offline
post #2 of 10 Old 06-29-2006, 01:37 PM
AZ Jeff
2014 JK Wrangler
Start by looking at your left front wheel bearing assy, and the brake rotor/caliper.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #3 of 10 Old 06-29-2006, 01:42 PM
x99j
i had similiar symptoms as yours. i finally narrowed it to a bad wheel bearing by taking the wheel off then taking the caliper and rotor off and spinning the hub. i could then feel the bearing going and causing my howl. instead of turning smooth it was very ruff turning. if you need a new hub bearing remember that 99 has two styles of hubs. one for cast rotors one for composite rotors. mike
06 kj 3.7l, 6speed manual, np241 command track
91 yj 2.5l, ax-5, np 231 3 inck lift, 31'' mud rovers
12 kk 3.7L, 42rle, mp1522, d-30, 8.25.
x99j is offline
post #4 of 10 Old 06-29-2006, 03:11 PM Thread Starter
Xride
I figured it had to be the wheel bearing/hub (its one peice isnt it?) and not the diff, just need to make sure.
The stupid dealer is swearing up and down the work was done, when I have 2 shops now that have said there is no way the part was repaced with a new one.
Well any more suggestions of what it could be befor i go down and crack some skulls?
Xride is offline
post #5 of 10 Old 06-29-2006, 03:57 PM
anony91xj
Definitely sounds like a wheel bearing, although there is somewhat of a chance it could be a diff bearing. Usually it's a wheel/hub bearing though.
If the dealer didn't change it, go back and tell them the noise isn't fixed. Make them re-do it.
1998 VW GTI 2.0
anony91xj is offline
post #6 of 10 Old 06-29-2006, 07:49 PM
smac999
I have a bad noise too when turning right. only when coasting. not while on the gas.
the dealership has changed both front wheel bearings and the back right. (2 different trips)
and it's still there
I guess it might be the back left one doing it.... *******es. I've given up for the time being.
I'm not really sure why a bearing noise would change with on / off thottle though???
I keep thinking it might be the LSD, or a u joint.
but it's been there for over a year and hasn't goten any worse...
99 XJ classic, 242, upcountry, towing, 8.25 rear w/ trac lock. drop in K&N, hella h4 ecodes
smac999 is offline
post #7 of 10 Old 06-29-2006, 08:27 PM
alexrule123
alexrule123's Avatar
how do you figure out if you have cast rotors or composite rotors?
2001 Cherokee Limited:
2005 Pontiac GTO 6.0L (DD)
alexrule123 is offline
post #8 of 10 Old 06-30-2006, 01:26 PM
x99j
call the dealer with the vin they will be able to tell you. also i don't no the measurements, but the rotors are about 1/4 inch different in height.
x99j is offline
post #9 of 10 Old 06-30-2006, 01:33 PM
Xj'sR'Creamy
I cannot tell without actually hearing it first hand, but also keep your powersteering pump in mind, it will make those sounds when the beraing inside is going bye bye.
Sean
"Let the divine arguments of existance drive us to starvation until all of our knowledge is exhausted into the very existance we have denied ourselves."
-Sean J Godfrey
Xj'sR'Creamy is offline
post #10 of 10 Old 06-30-2006, 03:24 PM
anony91xj
Only when coasting could be gear lash or a diff problem.
1998 VW GTI 2.0
1999 Jeep Cherokee - Howl/Whine in rear end ShaneHD XJ Cherokee Technical Forum 12 11-14-2015 08:58 AM
Changed DS front U Joint now I have Diff fluid leaking? scuba413 XJ Cherokee Technical Forum 1 05-09-2009 11:09 AM
wheel bearing? hub? u-joint? I6Waggy XJ Cherokee Technical Forum 3 04-10-2009 09:20 AM
U-joint, wheel bearing question Tosa XJ Cherokee Technical Forum 15 12-17-2008 06:04 PM
Axle gearing woes...whine/howl HeavyMetal XJ Cherokee Technical Forum 14 11-23-2008 08:06 AM
