#1 | |
Front end vibration/shimmy
Can figure this one out. My stocker had the beginings of DW and I suspected it to be the tires. I replaced the tires and the symptoms went away. A few days later adn I start to get a pulsating in the front end around 60mph. I rotated the tires to isolate maybe a bad balance and it got worse. Had it aligned today and it made no diff. Thoughts?
2002 Sport: I6, 4.56 gears, SYE, RE 3.5", 305 BFF MTs.5-spd,d30/d44. 2004 Grand: I6, wife's 1998 XJ: My daily driver. I6 "The Second Amendment is not about duck hunting, and I know I'm not going to make very many friends saying this, but it's about our right, all of our right to be able to protect ourselves from all of you guys up there." - Dr. Suzanna Gratia Hupp, appearing before Representative Charles Schumer's committee hearings on the assault weapons ban |
#2 |
Little buddy
My XJ does that too but a lower speeds, I had it checked and the shop couldn't find anything. Its driving me crazy. Anyone have any suggestions?
#3 |
Have you checked all the front end parts, tie rod ends, ball joints, etc. Is there mud in your rims? You said you had the front tires replaced but the rear could still be the culprit, but you did say it was fine for a couple days...It could also be a driveline vibration.
If you got an alignment they should have checked all your front end parts before aligning it. So I would go back to the place that did your tires and have them check the balance...
1999 Jeep Cherokee SE l 4.0 HO l AW4 l NP231
Dana 30/Chrysler 8.25 l 31x10.5x15 Wrangler MT/R Flowmaster Delta 40 w/stock pipes Optima Yellow Top l Custom Headlight Harness Alpine CDA-9886 Last edited by KamekLocked; 04-01-2007 at 06:38 PM.. |
#4 |
Having the same problem on my 98 xj with 3" at between 55-60mph sometimes its worse then others. Checked the front end had tires balance numorus times nothing is helping even changed wheels.
#5 | |
The Guru of Nothing
-Kyle
North Bay, CA Jeepers Post Here My Build Thread ~My Write Ups~ It's Not Just a Jeep, It's a Lifestyle
#6 |
TC is dropped 1 inch
#7 | |
The Guru of Nothing
-Kyle
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
