Quantcast Front End Vibration - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Front End Vibration
TJ 5.25" Speaker Adapters - NalinMFGSpartan Lockers FREE SHIPPING Excellent PricesRough Country Deals at JeepHut.com
Old 06-20-2005, 09:57 PM   #1
Stevelthrman1
Front End Vibration
Hey All. I'm new to the Jeep forum. I bought a 2000 Cherokee 4.0 4 door 4spd auto in February 2005 with 72000 and I have put on about 5000 miles since then. I love my Cherokee and it runs great and wish I would have got one sooner. About a month ago, while driving down the road, I hit a small pothole or some uneven surface in the roadway and the front end began to shake violently and feels like the wheels are going to fall off. From then on from time to time, depending on the bump and my speed, it will vibrate out of control until I either speed up or slow down below 20mph. It occurs around 35-40 mph. Any ideas on how I can fix this? I haven't done any extreme offroading, the XJ is completely stock except for the stereo and I drive it easily and do not beat it around. Also, is there any slight modifications that I can do to increase horsepower and gas mileage without costing me alot of money? What would you all recommend? Thanks.
Stevelthrman1 is offline   Reply With Quote
Old 06-20-2005, 10:29 PM   #2
d-man5000
1993 XJ Cherokee
DEATH WOBBLE. youre steering stabilizer is dead. that and look at your tie rod ends. they could be busted. samething happened to me and i almost peed my pants the first time it happened
'93 Jeep Cherokee Sport
5.5" RE Long Arm
Warn Hub and Chromeolly Dana 30
Ford 9" w/ Mini Spool
Toyo Open Country M/T's 33-13.50/R15
Warn Bumpers (Both)
d-man5000 is offline   Reply With Quote
Old 06-20-2005, 10:32 PM   #3
xj89
ok first off death wobble has nothign to do with a steering stabilizer, dont give bad information . the most likely casue for your death wobble is the fram mount of the track bar, remove the coter pin and crank it down. check your controel amr bolts, actually check every bolt. Get an alignment, and make sure your tires are balance properly.
74 CJ5
86 CJ7
89 Cherokee
xj89 is offline   Reply With Quote
Old 06-20-2005, 11:11 PM   #4
Cosmonut
Ouchies he was trying to give some information on what he knew!
98 Cherokee Sport - SOLD
3" Rustys AAL
A-1 Auto Header, Custom 2.5 Exhaust
Green Jeep Club Member #133
Cosmonut is offline   Reply With Quote
Old 06-20-2005, 11:32 PM   #5
creature
^What he said... A steering stabilizer is a band aid for other problems.
-Shawn
creature is offline   Reply With Quote
Glock Forum
