Front End Vacuum - JeepForum.com
post #1 of 6 Old 08-17-2002, 11:48 AM Thread Starter
CruzNlife1
CruzNlife1's Avatar
Front End Vacuum
Hmm, you guys are mentioning some sort of vacuum hose going to the front end so it disengages, well i have no hose, just a hole on the top right with nothing in it, and oil leaking out of it, tranny shop guy told me it was a breather plug missing and i have to get a new one from the dealership, could this be where the vacuum line goes ????, if your under the jeep its on the top passenger side, it leaks fluid slowly, than it has never disengaged, the front wheels are always "Locked In"
1989 Jeep Cherokee XJ LIMITED....2door.... Auto, NP242 4x4...
1996 Ranger Supercab....
1991 Mustang LX....
VERY SOON TO BE A BRAND NEW TJ OWNER, TRYING TO LEARN AS MUCH AS POSSIBLE RIGHT NOW !!
CruzNlife1 is offline
post #2 of 6 Old 08-17-2002, 12:23 PM Thread Starter
CruzNlife1
CruzNlife1's Avatar
??????? Or does somebody possibly have a schematic type something or a shot out of a workshop manual ????
1991 Mustang LX....
post #3 of 6 Old 08-17-2002, 03:31 PM
85XJ
If your talkin about the hole on the top of your diff, that is a breather/overflow hose for your gear oil. That has nothing to do with front end engaging to 4wheel. It just allows air to escape and overflow gear oil to go. Just stick a 5/8" hose to the diff and run it about 3feet up under the hood.
85 XJ / 8" skyjackerrock ready& custom lift / 35x12.50r15 Kumho MT's on 15x10 Rock Crawlers / 4.56 gears / Detroit locker rear-Lockrite front / Bushwacker flares / Slot drilled rotors / detachable swaybar links / Rancho & Skyjacker shocks / 32 gallon tank / Webber carb conversion / posi lock axle engagement /Shania Twain sticker
85XJ is offline
post #4 of 6 Old 08-17-2002, 03:32 PM
pair8hd
pair8hd's Avatar
Post
What year XJ? They stopped making the vacuum disco axle in 1990.
That is your differential vent, and it needs a tube that goes to the engine department to keep dirt, water and other foreign particles from entering your differential housing.
pair8hd is offline
post #5 of 6 Old 08-18-2002, 12:10 AM Thread Starter
CruzNlife1
CruzNlife1's Avatar
its an 89
1991 Mustang LX....
post #6 of 6 Old 08-18-2002, 10:06 PM
cladinshadow
Rock on dude, I swapped in an '89 dana 30 to my front. 85 XJ's right, run a vacuum hose up to your engine. It'll keep the crud out and let it breathe. If you want true part-time 4wd, you need to install hubs.
Darren
96 XJ
"Oh, thank god. It's some sort of rescue toaster."
cladinshadow is offline
Vacuum device on front axle ?? EG00TJ XJ Cherokee Technical Forum 18 10-19-2007 09:12 AM
Q about vacuum canister in front bumper jeepbro's XJ Cherokee Technical Forum 12 09-10-2007 07:19 PM
where are the vacuum lines to the front vacuum canister??? Elliottm2333 XJ Cherokee Technical Forum 3 03-13-2007 10:26 PM
Vacuum lines for front diff summitlt XJ Cherokee Technical Forum 0 08-01-2005 12:56 PM
need help on 91 w/ select trac.....do I have front vacuum d/c??? help!! w/in vandelay101 XJ Cherokee Technical Forum 10 10-02-2003 07:35 AM
