Quantcast Front End Noise - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Front End Noise
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!TJ WW2WW rockers on sale with free gaskets this month.
Old 07-01-2008, 02:18 PM   #1
THISISWEIRD
Front End Noise
So, I just picked up a 99 Jeep yesterday to join the club. (not sure I actually was invited to join the club, or know the name of said club, but anyway...)
It seems to be in great shape with only 59K miles and has virtually no rust.
Driving it home last night it was great, but today at slow speeds on the way to work, it makes a noise in the front end when I go over a bump. It may be the way a Jeep is, but it reminds me of lose struts, or struts going bad.....sort of a clunk.
I've pulled on the coils and shocks as well as the lower arms, and everything seems fine. Doesn't look like anything has ever been wrecked or even replaced on the front end.
Any ideas?
THISISWEIRD is offline   Reply With Quote
Old 07-01-2008, 02:29 PM   #2
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
Disconnect the shock and cycle it manually. Could be a simple as a bad shock. Other things to look at are:
Sway bar bushing on the bar mounts.
Sway bar bushings at the end link.
Shock bushing.
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
http://www.cardomain.com/ride/325707/1
http://www.cardomain.com/ride/2406854/1
balloo93 is offline   Reply With Quote
Old 07-01-2008, 02:43 PM   #3
THISISWEIRD
Just went out there to shake things around a bit to see what was loose. Those bushing mentioned seem to be fine. The bumpstop on the passenger side has dry rotted and is laying inside the coil.
I guess I need to figure that out.
EDIT:
I can't afford to lift it quite yet, but I need to get the bumpstop fixed. Any suggestions on the best item that will work for now and later on?
Old 07-01-2008, 02:47 PM   #4
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
Start looking for shiny metal spots as well on the sway bar end links and the coil springs.
93 Sport
Specs in Profile.
Old 07-01-2008, 02:48 PM   #5
THISISWEIRD
The shiny spots are metal to metal contact?
What are you thinking here?
Old 07-01-2008, 02:57 PM   #6
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
Yep. If the bar has shifted over it may be contacting something as the suspension compresses over a bump. That would give you a thud noise. So would wore out Bar pin bushings on the shocks.
The shock problem is fairly common. The sway bar shifting is not as common.
93 Sport
Specs in Profile.
Old 07-01-2008, 03:04 PM   #7
THISISWEIRD
Thanks a bunch. I'll look over all of that stuff again.
What about the bumpstops? They appear to be welded into place (99). Can I replace those?
Old 07-01-2008, 03:11 PM   #8
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
Yes, they pull out and push in.
93 Sport
Specs in Profile.
Old 07-01-2008, 03:28 PM   #9
THISISWEIRD
Thanks again!
Glock Forum
