Quantcast Front end noise? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Front end noise?
TJ WW2WW rockers on sale with free gaskets this month.DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-TJ 5.25" Speaker Adapters - NalinMFG
Old 11-14-2007, 07:31 PM   #1
linkovich
Front end noise?
The last few weeks I've had a noise coming from the front end that I can't figure out. Sounds like a bad bearing and its only when I'm rolling. I jacked it up and checked for any play or slop in the wheel bearings and the U joints and they all seemed ok. What else could it be or what else should I check?
oh yeah, 2000 4x4 4.0
linkovich is offline   Reply With Quote
Old 11-14-2007, 09:32 PM   #2
severous01
ummmm....tires? what brand/make do you have? if you have some serious meats they'll sound like a grinding sound when they wear unevenly. or, if you have what's called feathering of the tires...it sounds like a wheel bearing.
i was chasing my own tail after a feathered set of tires once. i replaced all joints and bearings in the driveline...nothing. then i rubbed my hand across a tire one day and found the front of each tread block had meat while the back of each block had almost none....weird.
1994 jeep cherokee, xj, 3" rough country springs / bilstein 5100's, 31" tires with trimmed fenders, aussie locked front diff, herculined ext, hella FF75 driving lights on factory fog location
[COLOR="Lime"]soon to be[/COLOR] 4.11 gear and and a ford 8.8 LSD rear and herc'd interior
severous01 is offline   Reply With Quote
Old 11-15-2007, 03:18 PM   #3
linkovich
I just have bridgestone dueler AT's right now, they're pretty much worn i guess that could be it.
Old 11-15-2007, 03:41 PM   #4
sprintagogo
It's not just me then?
I have what sounds like a similar noise on my 2000 4ltr XJ. I would swear it was a wheel bearing except it doesn't change when cornering and there is no detectable play in the bearings. It does seem to be getting louder over the last few months. I have messed around running with just a rear prop then just a front prop and this makes no difference. I am reasonably sure it must be a front axle bearing probably in the front diff. I should know for sure in the next few weeks when I swap out my low pinion axle for an earlier high pinion D30 (unless that one is also bad, My friend said it was silent when I towed the doner vehicle home with a dead engine). I have also changed tyres from stock road tyres to bigger mud terrains and these dont generate any detectable noise above the bearing rumble. I will post again with the results once the deed is done.
Rollin on 32'zzzz
Originally Posted by Muddeprived View Post
Who's eric?
Originally Posted by HornedFrogHooah View Post
Sprintagogo, you're absolutely amazing. I don't care what they say about yall over across the pond - you're a godsend!
sprintagogo is offline   Reply With Quote
Old 11-15-2007, 04:10 PM   #5
Carnutzzz
I think I have the same noise from newish Michelins. Mine sounds like a light roar from the front end at anything over 45-50 I believe.
I've had the vehicle looked over and nothing was found. I think these are just loud loud vehicles.
2000 Cherokee Limited 4x4
1987 Porsche 911
"Every government interference in the economy consists of giving an unearned benefit, extorted by force, to some men at the expense of others." -Ayn Rand
Carnutzzz is offline   Reply With Quote
Old 11-15-2007, 04:37 PM   #6
XJumpmaster
I have a hp d30 on my 2000 and it also sounds like a bearing. It is speed dependent. From a low growl at low speeds to a loud whine at high speeds. Tires are fine and not due to MTs! It is in the front axle.
Sorry to hijack, but am curious about this as well.
XJumpmaster is offline   Reply With Quote
Old 11-16-2007, 10:45 AM   #7
linkovich
Mine seems to not be as bad at high speeds, or maybe I just can hear it. I have a buddy with an extra set of wheels and tires that I'm going to put on and see if that helps.
Old 11-16-2007, 05:20 PM   #8
midfat
Don't assume it's the tires just because there's no play in the hub bearing. I too had the same issue. My Jeep sounded like a freight train when I was driving at freeway speeds. I had it to the mechanic twice to check the front hubs. Both times, he told me everything seemed tight. He also told me it was probably the tires. I spent almost $600 on new tires and it didn't make any difference. Finally, I broke down, bought two new hub bearings and changed them myself. While the bearings were both still tight, when I pulled them, they were both shot. It literally felt as though the bearing was filled with gravel. Moral of the story, trust your instinct and don't put much credence in the old wives tail that bearing WILL have play in it if it's bad.
midfat is offline   Reply With Quote
Old 11-16-2007, 06:43 PM   #9
kafer1963
Midfat,
Perhaps you could read my recent post" front bearing hub assembly"?
I am contemplating what to do on mine. change out the whole assembly or just replace new bearings races and seals.
Which route did you go?
Sorry to hijack thread but I think their both related.
kafer1963 is offline   Reply With Quote
Old 11-16-2007, 06:46 PM   #10
linkovich
Originally Posted by kafer1963
Midfat,
Everything that i've read has said it much easier to just replace the whole hub assembly then try to just change out the bearings
Old 11-17-2007, 11:27 AM   #11
midfat
Midfat,
The entire hub assembly is one piece. Even if you could rebuild the assembly, I don't think it would be worth the time. Just slap in a new bearing and call it a day.
Old 11-17-2007, 07:24 PM   #12
Rob Hollar
An easy way you can find out if you have a bearing failure is to jack up your vehicle and use jackstands. With one hand place it on the coil spring and the other spin your wheel. See if you can feel a vibation in the spring. If you can then you have a bad wheel bearing. I am a local shop owner and I have found untold # of cars with bad bearings that way that had no slop. Good luck in your search...Rob
Rob Hollar is offline   Reply With Quote
Old 11-18-2007, 09:43 AM   #13
Carnutzzz
Thanks Rob, I'm going to try that.
1987 Porsche 911
Old 11-18-2007, 07:17 PM   #14
linkovich
I will try that in the morning, thanks for the tip
Old 11-18-2007, 07:39 PM   #15
crumb
I had a constant wine and tried a bunch of stuff to get rid of it. Finally I changed the gearing in my front dana 30 and the wine was gone. I replaced a pinion bearing that was bad. That is what was causing my noise.
So there is another possibility.
Good luck
My Jeep Cherokee
1999 Cherokee Sport
4.5" RE Superflex Lift
My Jeep Wrangler
2005 Jeep Wrangler LJ 3" Lift
crumb is offline   Reply With Quote
Glock Forum
