Front driveshaft rebuild questions-problems - JeepForum.com
post #1 of 12 Old 11-22-2007, 12:36 PM Thread Starter
citRon
2003 KJ Liberty
I'm rebuilding a front DS to use in the rear w/ the RE H&T. How hard should it be to remove and install new ujoints? To get the old ones out, I had to beat the living snot out of them with a hammer. I figured the new ones would go in easier-WRONG! I bent and broke 3 c-clamps trying to 'press' them in, and had to resort to the hammer and socket trick, and again- beat the living snot out of them to get them in! I've never replaced ujoints before, so I don't have any experience to compare. It just seemed really violent treatment for something as precise as little ujoints with itty bitty needle bearings in them, and I'm kinda worried I might have FUBAR'd something in the process.
1996 Cherokee Country 4x4
citRon is offline
post #2 of 12 Old 11-22-2007, 12:38 PM
XJK
The Guru of Nothing
XJK's Avatar
many people including myself use the socket method, never had a problem. you should be fine unless you can see physical damage to the ujoint.
-Kyle
It's Not Just a Jeep, It's a Lifestyle
XJK is offline
post #3 of 12 Old 11-22-2007, 12:42 PM
SuperStreetJeep
SuperStreetJeep's Avatar
1993 XJ Cherokee
did you buy the right joint?
Think Your Jeep Is Fast??? Click Here!!!
SuperStreetJeep is offline
post #4 of 12 Old 11-22-2007, 01:13 PM
95_TSi_AWD
1991 XJ Cherokee
you also have to make sure you don't knock over any of the little needle bearings. if it goes on easier then only gets hard right at the end then you probably knocked some over. make sure it moves smoothly when your done
95_TSi_AWD is offline
post #5 of 12 Old 11-22-2007, 01:16 PM
Rob Hollar
with the right tool it only takes about 15 to change a single ujoint....Rob
Rob Hollar is offline
post #6 of 12 Old 11-22-2007, 01:30 PM
98FleXJ
heat the yolk up, and use a bench vise and socket method, it will go much smoother
98FleXJ is offline
post #7 of 12 Old 11-22-2007, 02:36 PM Thread Starter
citRon
2003 KJ Liberty
ok- got them all in. -yep, got the right ones- 153's- Brute Force non-greasables (with the 'lifetime' lithium grease in them). Everything moves, but they are all a little 'stiff' - but they do move around, and I don't feel any scraping or roughness- should they be a little stiff, and have a little resistance to moving them by hand?
citRon is offline
post #8 of 12 Old 11-22-2007, 03:09 PM
XJK
The Guru of Nothing
XJK's Avatar
yes they will be a little stiff right out of the box but you shouldnt feel any binding because that means that you messed up a bearing on the install.
-Kyle
XJK is offline
post #9 of 12 Old 11-22-2007, 03:12 PM
SuperStreetJeep
1993 XJ Cherokee
ok now come do mine
post #10 of 12 Old 11-22-2007, 03:17 PM
Rob Hollar
Went I finish installing ujoints I take 2 small hammers and at the same time and opisit each other i tap just behind each joint. This seems to free up any binding there might be...Rob
post #11 of 12 Old 11-22-2007, 03:19 PM Thread Starter
citRon
2003 KJ Liberty
Originally Posted by SuperStreetJeep
ok now come do mine
ha! if I knew what a job it was beforehand, I would have taken the shaft somewhere and let them rebuild it- or at least taken it and the new joints to amachine shop or someplace to press them in.
Oh well, another lesson.
citRon is offline
post #12 of 12 Old 11-22-2007, 06:00 PM
TMCXJ
oops... nevermind
"...a long habit of not thinking a thing wrong, gives it a superficial appearance of being right, and raises at first a formidable outcry in defense of custom. But tumult soon subsides. Time makes more converts than reason." Thomas Paine
TMCXJ is offline
SYE and Rear Driveshaft Questions, Hack and Tap, install front driveshaft? Feorge_Goreman XJ Cherokee Technical Forum 21 03-14-2011 12:19 AM
7.5 lift/ front driveshaft questions sk8ertht540s XJ Cherokee Technical Forum 20 12-20-2008 09:41 AM
Front Driveshaft rebuild questions. glennv XJ Cherokee Technical Forum 2 03-28-2007 08:04 PM
Front Driveshaft Questions white98xj XJ Cherokee Technical Forum 5 01-05-2007 03:40 PM
RE HacknTap questions about XJ front driveshaft ColinMoore XJ Cherokee Technical Forum 21 08-07-2005 11:28 PM
