Front Driveshaft rebuild questions. - JeepForum.com
post #1 of 3 Old 03-28-2007, 06:11 PM Thread Starter
glennv
glennv's Avatar
I got a used front DS (to run with an SYE in the rear) from another XJ that had 220k on it so I plan to replace all the joints on the shaft. I pulled the U-joint that connects to the read end with no problems. Questions:
1. Does the double cardan end come apart the same way?
2. Are all the u-joints the same?
3. And what about the huge ball in the center of the double cardan, does that have to be replaced too? (There is a rubber boot looking thing on one side of the ball and it's torn.)
4. Does it need to be rebalanced?
2002 Sport: I6, 4.56 gears, SYE, RE 3.5", 305 BFF MTs.5-spd,d30/d44.
2004 Grand: I6, wife's
1998 XJ: My daily driver. I6
"The Second Amendment is not about duck hunting, and I know I'm not going to make very many friends saying this, but it's about our right, all of our right to be able to protect ourselves from all of you guys up there." - Dr. Suzanna Gratia Hupp, appearing before Representative Charles Schumer's committee hearings on the assault weapons ban
glennv is offline
post #2 of 3 Old 03-28-2007, 06:48 PM
Chris_Walker
Chris_Walker's Avatar
1988 XJ Cherokee
Sharpie has a writeup for this in the stickies...
http://www.jeepforum.com/forum/f11/cv-driveshaft-rebuild-part-deux-345170/
Chris_Walker is offline
post #3 of 3 Old 03-28-2007, 07:04 PM
dajeepman
Thanks I was looking to do the same with mine..but I was not gonna sue mine as a rear DS.
dajeepman is offline
SYE and Rear Driveshaft Questions, Hack and Tap, install front driveshaft? Feorge_Goreman XJ Cherokee Technical Forum 21 03-13-2011 11:19 PM
7.5 lift/ front driveshaft questions sk8ertht540s XJ Cherokee Technical Forum 20 12-20-2008 08:41 AM
Front driveshaft rebuild questions-problems citRon XJ Cherokee Technical Forum 11 11-22-2007 05:00 PM
Front Driveshaft Questions white98xj XJ Cherokee Technical Forum 5 01-05-2007 02:40 PM
RE HacknTap questions about XJ front driveshaft ColinMoore XJ Cherokee Technical Forum 21 08-07-2005 10:28 PM
