front driveshaft on 93 xj way to much vibration
| Truck-Lite's New LED Headlamp Series | TJ 5.25" Speaker Adapters - NalinMFG | CURRIE TJ/LJ/XJ/MJ HD Steering - Low Price Guarantee! |
#1 | |
i am having way to much vibration already put in u joints and a whole new but used shaft have total of 9 inches and also and tips on cheap lockout hub kits for dana 30 HP?? help it out
#2 |
hows your pinion angle? maybe the driveshaft is too short now?
#3 |
ther is no cheap locking hub kits !!!! unles you find a used one , pulled at junk yard , craigs list . And if they know what they have it still won't be real cheap, at least I have had no luck
![]() Brizzle
“Don’t Tread On Me” www.highsprings.com |
#4 |
I heart bacon and pie
If you mean 9 inches of lift then you will need to change your pinion angle. And doing that without turning the inner knuckles will reduce your caster. I recently put a wagoneer axle on the front of my XJ so I could have manual hubs. It costs over $1000 to get the XJ dana 30 hubs from warn.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
