Front Drive shaft - JeepForum.com
post #1 of 2 Old 05-23-2002, 07:01 PM Thread Starter
Lost Soul
Question Front Drive shaft
I have an 87xj, that I just picked up, and was a little stumped on this. I had it in to the shop for the safety and when it was on the hoist I tried to spin the front shaft( in 2wd ), it would not spin. The truck also has a strange whine while in the first three gears, and I wondered if it might be stuck in 4x4. When I pulled out of the garage I lit up the tires in the gravel then went through some water and did it again on the pavement, the tail kicked out nice like it was in 2wd?????? If any one can tell me what is going on It would make me very happy. The only other experience I have is with my 85, which also is a command trac, but that FDS spins freely?
Lost Soul
Lost Soul is offline
post #2 of 2 Old 05-24-2002, 08:09 AM
XJin96style
Post
Ok well it probably isn't your 4x4 since if it was everytime you would make a turn on dry pavement it would pull really hard and you would be screwing up the front end. It might be the front diff check the fluid inside the diff also it could be your bearings at the end of the axle. It would be a good idea to check them.
/\/\/\/\ is here!!!!
2000 XJ Jeep sport stock
"ITS A JEEP THING, DONT TRY TO FOLLOW YOU MIGHT GET STUCK."
XJin96style is offline
No front drive shaft navarremro XJ Cherokee Technical Forum 7 04-02-2009 10:22 AM
Front drive shaft? scupking XJ Cherokee Technical Forum 6 08-10-2008 11:09 PM
Front drive shaft eflores XJ Cherokee Technical Forum 6 01-16-2008 04:21 PM
front drive shaft + SYE 96cherokeeclass XJ Cherokee Technical Forum 1 02-12-2007 03:15 PM
front drive shaft as a rear drive shaft jeepsteads XJ Cherokee Technical Forum 42 12-15-2006 11:09 PM
