Front door latches on rear doors? - JeepForum.com
post #1 of 4 Old 05-11-2013, 05:22 PM Thread Starter
AdamZJL
I have 2 Cherokees at the moment, a 93, and a 98. Neither of them the back doors will open, door latches on the rear doors are seized on them both.
I'm just wondering if the front door latches from the 93 will work on the rear doors of my 98, just for the sake of saving me buying some.
1998 Jeep Cherokee Sport, 3" Zone lift w/ 33" Daytona Super Stags.
AdamZJL is offline
post #2 of 4 Old 05-11-2013, 07:32 PM
Muddy97Cherokee
1997 XJ Cherokee
You would probably have to drill new holes on the body to make them fit correctly. For one, the front and rear hinges work in completely different ways and are styled differently on both jeeps. Not only that but the difference between pre97 and 97+ hinges are greatly varied. They don't look or work the same at all. It could probably be done but with the time wasted on trying would not be worth it.
1997 XJ Sport
6.5" with 31's
Built to CRAWL
IG: zack_hstadt
-ZACK
Muddy97Cherokee is offline
post #3 of 4 Old 05-12-2013, 08:24 AM
AZ Jeff
2014 JK Wrangler
Rear latches are not the same as front. They won't work. Remove your existing latches and soak them in some pentrating oil, and then exercise them outside the vehicle until they work smoothly.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
post #4 of 4 Old 05-13-2013, 09:29 AM Thread Starter
AdamZJL
Well, on every jeep i've owned i've had at least one of the rear door latches seized and i have yet to remove one without destroying it unless i'm going about it wrong.
I'll just get a couple junk yard ones, should be fine as long as i keep using the rear doors, any tips to removing them without having to break them? The one i did before i had to drill through from the inside and break the latching mechanism to get it open.
AdamZJL is offline
