Front differential lose and makes noise - JeepForum.com
post #1 of 5 Old 12-28-2011, 06:39 PM Thread Starter
amatotime
i have a 1999 jeep cherokee and the front differential makes a grinding type of sound and it leaks oil. Also im not sure what its called but the large nut that seats the yoke which the yoke sits on it moves back and fourth and i can wobble it. I really need help to find out how to correct this!!!! Any advice please let me know!! Thanks!
amatotime is offline
post #2 of 5 Old 12-28-2011, 07:15 PM
Rmart30
Sounds like it needs pinion bearings and seals at the least......... pull the cover and drain the oil and see how much water or metal shavings it has in it.
Currently own 93 XJ 33's on 4" lift....01 XJ stock,will replace my 93 after mods are done..... 1994 ZJ V8, BB w/31's........99 XJ stock....97 XJ 2wd 5 spd stock.... and just p/u a 98 XJ 4wd/5 spd and a 01 XJ
Rmart30 is offline
post #3 of 5 Old 12-28-2011, 09:22 PM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
If you need to rebuild, it may be cheaper to bolt on a good used axle instead. Expect to pay $5-800 for a differential rebuild. You can install an axle in your driveway with simple hand tools. Rebuilding the differential internals requires some specialized tools and specific technical knowledge.
CJ7-Tim is offline
post #4 of 5 Old 12-29-2011, 06:09 PM
Desertwheeler
Sounds F'd up for sure. Certainly a diff rebuild needs to be accomplished.
2000 TJ Crawler- 5.5 lift w/14in coilovers, HP44, ARB, Cromo's, 300m Joints/D60, Detroit, D80 35spl shafts. Full hydro, OBA, OBW, Flipped D300 W/4:1 kit, custom cage etc.
2001 Cherokee Sport, 4.5 RC Longarm, 33 Duratrac's, SYE, 4:56's, Front HP30 w/Lockrite, Autopals- Sold
Desertwheeler is offline
post #5 of 5 Old 12-29-2011, 07:03 PM
rshrimp
If you can move the yoke with your hand the ring and pinion are destroyed for sure. I agree, I would be looking for a good used front end. WAY CHEAPER than fixing this one and WAY easier to install.
2012 JK 2-dr White Rubicon Hard Top. Myakka City FL/Okeechobee FL
rshrimp is offline
diff leak , differential , differential fluid
Knocking noise in front differential? nyaben XJ Cherokee Technical Forum 3 02-28-2011 02:53 PM
Cherokee makes creeking noise when turning *After front end collision* PlaySmart XJ Cherokee Technical Forum 7 09-21-2010 03:08 PM
Front differential noise? Phil12 XJ Cherokee Technical Forum 8 08-30-2010 02:54 PM
Front Differential noise djkirwin XJ Cherokee Technical Forum 4 06-16-2008 04:32 PM
front end makes noise and water under mat ???? loadder XJ Cherokee Technical Forum 4 08-25-2007 08:24 AM
