front caliper 97 xj - JeepForum.com
post #1 of 6 Old 07-14-2017, 03:32 AM Thread Starter
funnyjeeper
Xj front caliper 97 xj
Hallo together,
I have some problems with my front brakes.
The caliper dr side seams not to open complete once in a while. Then you have a bad smell, have to wait and with some luck the caliper is open again.
I had this problem on vacation and went to a garage and got it fixed, - high price but bad quality! - the calipers are new... and the problem happend already again.
I do not want to go with big brake kits, I like to, but I run 30x9.5 r15 and this should be okay with the single piston caliper.
What brand do you guys consider good quality and do you have positve experience?
Another Question is: A guy in germany is selling brake caliper for CJ7 86 and XJ 90 + ? Do both use the same calipers?
I couls not believe it.
Thanks
frank the funny jeeper
funnyjeeper is offline
post #2 of 6 Old 07-14-2017, 04:43 AM
SemperFiGuy
1980 CJ5
Did you get new soft lines as well? Also how bout the knuckle is there a groove in it where the caliper rides? I bought super crap calipers from Advanced and got almost a year out of them before warranting the RH side.
I run 31's, and I know some are running bigger than that on the stock caliper.
Sent from my SM-T230NU using Tapatalk
SemperFiGuy is offline
post #3 of 6 Old 07-14-2017, 04:53 AM Thread Starter
funnyjeeper
I already changed the lines into stainless.
post #4 of 6 Old 07-14-2017, 04:59 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
CJ D30 and XJ D30 do not interchange parts. 1993-98 ZJ Grand Cherokee brakes will fit.
Check the brake pad sliding surface for wear. They should be smooth and flat. As already suggested, install new flexible brake lines.
CJ7-Tim is offline
post #5 of 6 Old 07-14-2017, 05:00 AM
SemperFiGuy
1980 CJ5
I meant the flexible line from hard to the caliper.
post #6 of 6 Old 07-14-2017, 11:03 AM Thread Starter
funnyjeeper
I replaced them last year:
Jeep Cherokee XJ Grand ZJ Wrangler YJ TJ Stainless Steel Extended Brake Line Kit
And cj7 Tim thanks I will have a look.
