Quantcast Front Brake Rotor size? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Cherokee Technical Forum > Front Brake Rotor size?
Old 05-28-2007, 09:56 PM   #1
skenzer
Hi everyone!
On my 2002 TJ I had a heck of a time when I changed the front rotors in figuring out what the proper overall height of the rotor was supposed to be.
I now notice that when shopping for a new set of rotors for my 2001 Cherokee that I'm being offered two different heights...3 3/16 and 3 1/16. I guess I could take the tire off and measure the rotor height but does anybody know which would be correct? Do I need to check the date of when my jeep was actually manufactured in order to know which rotor height is correct?
thanks for any help
Skenz
2001 Cherokee Limited
2" BDS Lift
K&N FIPK Series2
Magnaflow Cat-back
62mm ported TB
Optima Yellow Top
Lot's more to do....
skenzer is offline   Reply With Quote
Old 05-29-2007, 09:40 AM   #2
AZ Jeff
On a 2001 it's about 98% certain you will have the shorter rotor
AZ-Jeff
1992 XJ 2" lift -- RIP
2000 XJ 3" lift -- Australian Ford Big Brakes up front, rock rails, ZJ rear discs (with WORKING parking brake), C4x4 rear bumper/tire carrier, Hella H4 headlights, IPF driving lights, OEM skid plates, OME springs/shocks, JKS LCA's, JKS Sway Bar links.
AZ Jeff is offline   Reply With Quote
Old 05-29-2007, 10:02 AM   #3
CJ7-Tim
Go Jeepin
CJ7-Tim's Avatar
Just look at the unit bearing hub. Read this first - http://www.jeepforum.com/forum/f11/any-difference-hubs-360959/?highlight=rotor
FOR SALE: Wide Track CJ-7 Dana 44 rear axle.
PM me for details
A Government big enough to give you everything you want, is a Government big enough to take from you
everything you have. The course of history shows that as a Government grows, Liberty decreases.
CJ7-Tim is offline   Reply With Quote
Old 05-29-2007, 10:13 PM   #4
TPI Monte SS
I just went through this with my '01. I have the 3 1/16" rotors; pretty sure you'll have the same.
Steve Ragusa - North Jersey
'01 XJ - SOLD!
'06 Infiniti G35x - New DD. :)
'03 KJ Limited -WifesJeep- 3.7, Auto, NP 242, '06 Limited 17's. 40K miles.
TPI Monte SS is offline   Reply With Quote
Old 05-30-2007, 12:08 PM   #5
skenzer
Thanks everyone...appreciate the help and the info!
2" BDS Lift
K&N FIPK Series2
Magnaflow Cat-back
62mm ported TB
Optima Yellow Top
Glock Forum
