Front Axle U-Joint clarification/help - JeepForum.com
post #1 of 8 Old 09-07-2010, 05:34 PM Thread Starter
donthelegend
I am replacing the u-joints on the front axle of my 2000 and just want to clear a few things up. First, according the stock specs sticky, I need 5-297x joints (correct me if I read it wrong). It seems that the 760x joints are supposed to be the same, but stronger. Are these the same size, just different part numbers (I know the 760x is a forged cross and supposedly stronger)? So I could get either 760x or 297x or do I need to make sure they're 297x's?
Second, where does everyone get Spicer U-joints? In the past, rockauto has been recommended, but they don't have the spicer joints listed now. I'd like to get greasable joints if possible.
I found this:
Amazon.com: Spicer 16525.06 Greaseable U-Joint for Front Axle Left or Right: Automotive
Looks like what I'm looking for, but details are a bit lacking, can anyone confirm this?
Or these:
Amazon.com: AlloyUSA 11500 Forged X-Joint For 5-297X And 5-760X U-Joint Replacement: Automotive
Has anyone used AlloyUSA joints, good, bad, or otherwise?
Thanks for all the help!
donthelegend is offline
post #2 of 8 Old 09-07-2010, 06:34 PM
justanotherjpr
760's will fit fine and are stronger than the 297's. Unless you're running big tires or plan to run big tires, you would probably be OK with joints from your local NAPA. I bought my 760's from Action Machine for nearly half the Amazon price at: Spicer 5-760X Axle U-joint inside snap ring . I've never used Alloy USA joint and don't know anyone that has - but I'm sure someone will chime in.
So do you actually hear your thoughts in your head or is it just sort of a dull roar before you smash your face into your keyboard and just submit whatever dumb **** ended up on the page?
justanotherjpr is offline
post #3 of 8 Old 09-07-2010, 06:40 PM
robsjeepxj
The Spicers are the highest quality stock joints made. You'll be hard pressed to find another joint that will go 100,000 miles+ like the factory Spicers will. You want the 760x I've run both the AlloyUSA and the Spicers the AllloyUSA ones may be slightly stronger but not by much. For stock shafts either one is fine. If you get the greaseable joints then you'll have to grease them fairly often as the seals don't usually last long or seal as well as the non-greaseable ones that came from the factory. You don't need them to be greaseable at all it's just that people like to have them if they do alot of water crossings or muddy/watery trail riding.
robsjeepxj is offline
post #4 of 8 Old 09-07-2010, 06:45 PM
justanotherjpr
This is a good point - if you can, go with the Spicer's.
post #5 of 8 Old 09-07-2010, 11:19 PM Thread Starter
donthelegend
Thanks for the replies. I'm leaning towards the greaseable joints because while I don't go looking for water crossings, there are a lot of mud/water pits where I wheel so water above the axles is quite common. Greasing them often is not a problem. Any comments on the AlloyUSA joints? Or other places to get greaseable spicer joints? I don't see greaseable joints on the site justanotherjpr mentioned.
post #6 of 8 Old 09-07-2010, 11:46 PM
robsjeepxj
Denny's driveshaft is one Quadratech is another. Ironrockoffroad too.
post #7 of 8 Old 09-08-2010, 01:40 PM Thread Starter
donthelegend
Thanks for the help, ended up getting sealed 760's from denny's driveshafts. Now i just hope I don't have too many issues replacing them!
post #8 of 8 Old 09-08-2010, 01:59 PM
robsjeepxj
Check the FAQ/Tech Section there's a few good write ups in there on changing axle u joints that should be helpful.
spicer , ujoint
Front Axle U-Joint SolerXJ XJ Cherokee Technical Forum 5 06-16-2010 07:09 PM
Front Axle U-JOINT PLEASE HELP!! Green97Cherokee XJ Cherokee Technical Forum 10 03-07-2007 08:19 AM
cv joint front axle swap djfreema XJ Cherokee Technical Forum 2 09-04-2006 08:24 PM
front axle joint Beeker356 XJ Cherokee Technical Forum 3 08-18-2006 06:57 PM
Front axle U-joint Bob Hopkins XJ Cherokee Technical Forum 4 07-14-2004 05:19 PM
