Front axle removal - JeepForum.com
post #1 of 8 Old 06-15-2009, 01:56 PM Thread Starter
JeepJinx
Front axle removal
JeepJinx is offline
post #2 of 8 Old 06-15-2009, 02:04 PM
robbuck
should be a fairly easy removal and those seals should be fine. Just inspect the shafts when you remove the diff cover and look for metal burrs or fragments- things that might catch or tear the seals - otherwise they should just slide right out... most likely you'll be fine.
robbuck is offline
post #3 of 8 Old 06-15-2009, 02:21 PM
fitbmxseries1
1987 YJ Wrangler
one of my seals leaked on my 99 after pulling the axle shaft. so they now have to come back out agian for me to replace the seal. If you are so inclined to pull the diff cover off and the carrier out its probably adds about half hour more work to replace the seals when the axles are already out. Look up some of the how tos on this forum. but if your carefull and they are in good shape you should be good... Should be.
fitbmxseries1 is offline
post #4 of 8 Old 06-15-2009, 02:55 PM
lowicz96
1995 XJ Cherokee
I pulled both axle shafts to replace the u-joints and got lazy with the passenger side. It leaked alittle but wasn't bad enough to replace the seals just yet. Take your time and you'll be fine.
Project/DD - 95' Cherokee Sport, 2 Door, Converted to 4x4, AX-15, NP231, Black and lots of other goodies
88' Cherokee Limited - RIP
Sold - 96' Cherokee Sport 4x4, 2 Door, AW4, NP242, Its the girlfriends now!!
lowicz96 is offline
post #5 of 8 Old 06-15-2009, 03:27 PM Thread Starter
JeepJinx
JeepJinx is offline
post #6 of 8 Old 06-15-2009, 03:32 PM
xjfever
xjfever's Avatar
1995 XJ Cherokee
The diff. cover doesn't have to be removed to replace the axles, but it does to replace the seals.
xjfever is offline
post #7 of 8 Old 06-15-2009, 03:32 PM
robbuck
you don't have to pull the diff cover to pull the axles. But... since you're replacing the other parts an inspection and a fluid change can't hurt - might be good to know that everything is running smooth in there.
robbuck is offline
post #8 of 8 Old 06-15-2009, 04:04 PM Thread Starter
JeepJinx
JeepJinx is offline
Front end supports. (for axle removal) svshaw82 XJ Cherokee Technical Forum 5 01-06-2010 11:02 PM
Front Axle seal removal lindope XJ Cherokee Technical Forum 5 06-01-2009 07:56 PM
Front Axle U-Joints removal blackgnx XJ Cherokee Technical Forum 8 06-04-2007 09:17 AM
Front axle shaft removal Cherokeefan XJ Cherokee Technical Forum 8 10-10-2005 10:07 AM
Front axle shaft removal/bearing questions/observation IndyXJ XJ Cherokee Technical Forum 3 02-12-2005 10:08 PM
