Front axle issues - JeepForum.com
post #1 of 3 Old 04-02-2011, 12:53 AM Thread Starter
dgm89
1997 XJ Cherokee
Front axle issues
I had a question about some front axle problems I am having. I have a 97 XJ with a Dana 30 front axle. About 2 or 3 months ago, I started hearing a popping noise when I turn either direction. It didn't start out that loud, but it has gotten quite loud lately. I have checked out the front end parts, and ball joints, steering arms, and all bushings seem to be ok. It only pops when the jeep is moving, and only when I am turning. Because of this I am thinking that it is the u-joints. Is that a correct assumption?? The reason I say this is because I can sit in one spot and crank it back and forth and no popping at all. So would you guys say that it is just the u-joints??
dgm89 is offline
post #2 of 3 Old 04-02-2011, 01:28 AM
95JeepFactory
1995 XJ Cherokee
I too am wondering this. I just replaced the whole front DS on my cherokee and i was thinking the front joints are bad too but havent driven it yet. Finsihing the rear axle shaft swap
95JeepFactory is offline
post #3 of 3 Old 04-02-2011, 03:44 AM
Timo_90xj
Timo_90xj's Avatar
I'd say the u-joints are bad, your description matches the usual symptoms.
***Under construction***
Timo_90xj is online now
axle , front end noise , u-joints
Possible Axle leak/brake lead on front axle alexk243 XJ Cherokee Technical Forum 11 12-03-2010 06:11 PM
I need help!! axle issues Eagle327b XJ/MJ Cherokee Non-Technical Forum 27 05-02-2010 05:46 PM
tj front axle in place of xj front axle dezertxj XJ Cherokee Technical Forum 7 02-12-2010 03:01 PM
Inner axle seal issues... TreddyoXJ XJ Cherokee Technical Forum 4 11-25-2007 07:08 PM
Front Axle issues (99XJ D30, 242TC) JayCO XJ Cherokee Technical Forum 16 07-12-2006 02:59 PM
