FRONT axle hop - JeepForum.com
post #1 of 9 Old 12-09-2010, 10:40 AM Thread Starter
cherokeekid58
FRONT axle hop
Hi I got a 4 inch lift with 32s on my 2000 xj and when I'm wheeling in mud and I turn my steering wheel more than half way my front axle will hop. In 4wd. Is this common or is it a bad thing? Thanks
[QUOTE=sonoran_Tj
"If we collect data long enough, we may discover the root psychological cause for the "jeep thing".
So far it seems correlated to OCD and the need to look at one's poop."
cherokeekid58 is offline
post #2 of 9 Old 12-09-2010, 10:43 AM
1990JEEPXJ
1990JEEPXJ's Avatar
1990 XJ Cherokee
axle hop is generally a characteristic of poor suspension geometry. are you running stock control arms in the stock location?
1990JEEPXJ is offline
post #3 of 9 Old 12-09-2010, 10:46 AM Thread Starter
cherokeekid58
No, aftermarket ones that came in the kit
[QUOTE=sonoran_Tj
post #4 of 9 Old 12-09-2010, 12:22 PM
donthelegend
Have you checked your u-joints? When mine were bad I would get really bad axle hop when I tried turning due to the joint binding and popping as the wheels turned.
donthelegend is offline
post #5 of 9 Old 12-09-2010, 03:50 PM Thread Starter
cherokeekid58
The passenger side u joint is bad, driver side is good but it's been doing this even before that. And it only does it when the wheels are spinning and the mud is flying
[QUOTE=sonoran_Tj
post #6 of 9 Old 12-09-2010, 03:56 PM
bmyohn
Youngin'
bmyohn's Avatar
Do you have an aftermarket trac bar as well?
2014 Jeep Wrangler Sport S
3.6L V6 - Manual
2001 Jeep Cherokee Sport
4.6L Golen Engine Stroker
6.5" TnT Customs Longarm Kitl Ford HP D60 l 6.5" Rock Krawler Coils l TnT Customs HD Trac Barl Omix Ada HD SYE l 1" UBEsl CV Driveshaft l39.5" IROKsl 17x9" Pro Comp 98sl High Clearance Shock Mounts [COLOR="red"] l Hidden Hitch l AJs Custom Front Bumper l SONY Xplod stereo l Alpine Speakers l TnT Frame StiffenerZ l 22" RE SS Brake Lines l 1.5" TnT Customs Boomerang Shackles l Sterling 10.25 *FULL WIDTHS* l JKS Mini Skids and Sway Bar Brackets l 7/8" Heim Joint High Steer
bmyohn is offline
post #7 of 9 Old 12-09-2010, 03:59 PM Thread Starter
cherokeekid58
Yep aftermarket trackbar as well
[QUOTE=sonoran_Tj
post #8 of 9 Old 12-09-2010, 04:00 PM
bmyohn
Youngin'
bmyohn's Avatar
How do your ball-joints look?
3.6L V6 - Manual
bmyohn is offline
post #9 of 9 Old 12-09-2010, 04:20 PM Thread Starter
cherokeekid58
Driver side are brand new, I don't know bout passenger side
[QUOTE=sonoran_Tj
Possible Axle leak/brake lead on front axle alexk243 XJ Cherokee Technical Forum 11 12-03-2010 06:11 PM
Front Axle L8RH8R XJ Cherokee Technical Forum 1 09-03-2010 12:17 PM
tj front axle in place of xj front axle dezertxj XJ Cherokee Technical Forum 7 02-12-2010 03:01 PM
xj front axle ? BeerMonkeY XJ Cherokee Technical Forum 3 09-09-2006 07:57 AM
front axle sweerik MJ Comanche Technical Forum 1 09-04-2006 09:57 AM
