Front Axle disconnect problems - Can I lock it in place? - JeepForum.com
post #1 of 7 Old 11-15-2012, 09:06 PM Thread Starter
Wiskey
1991 XJ Cherokee
Hello all!
I have a 91 XJ with the front axle that includes the vacuum disconnect. I'm starting to have some problems with it engaging and disengaging properly and I'd like to just eliminate it by locking it in the engaged position.
First, is this a good idea? Can I expect any repercussions from this when I drive the vehicle on the street? Will it hurt my gas mileage?
How about the Transfer case? If I lock this up, is it still okay to shift from 2 Hi to 4 Hi while rolling? Or will I grind gears now?
Lastly,.. what is the best way to lock it in place?
Thanks for your help!
Whiskey
Originally Posted by Rescue XJ View Post
Seafoam. . . Its the closest thing to an enema for your engine.
Wiskey is offline
post #2 of 7 Old 11-16-2012, 05:05 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
cruiser54 is offline
post #3 of 7 Old 11-16-2012, 07:46 AM
mountainjock
1988 XJ Cherokee
The best way?? I replaced the axle shaft with a solid shaft from the junkyard, not sure of the year. Then I got a CAD delete kit from Warn (pretty cheap). This comes with inner and outer axle seals, and a cover plate w/ gasket to cover the hole from the CAD 'pump'. Had to pull out my carrier, but to me this is the most durable way and made sense to me.
Edit: I have seen no ill affects in doing this.
COLORADO JEEP CLUB MEMBER # 312
88 XJ 3" Pro comp lift 31/10.50
231 TC
4.0 I6
mountainjock is offline
post #4 of 7 Old 11-16-2012, 08:42 AM
diskman_1
1992 XJ Cherokee
On my '84, I just used a large hoseclamp to hold the collar over. Worked great for me. I did develop a small leak on the driveshaft seal as it probably started turning more.
diskman_1 is offline
post #5 of 7 Old 11-16-2012, 09:30 AM
GetLifted
Deleted*
It's too early for me lol
GetLifted is offline
post #6 of 7 Old 11-16-2012, 02:35 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Yes, the simple mods work just fine.
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
post #7 of 7 Old 11-17-2012, 08:39 PM Thread Starter
Wiskey
1991 XJ Cherokee
That deal with moving the E clip worked fantastic! I did it today while I was doing my oil change and swapping out springs.
Thanks for the help!
Whiskey
Wiskey is offline
