Freeze Plug Size - JeepForum.com
post #1 of 4 Old 10-09-2006, 06:07 PM Thread Starter
StokedXJ11
1997 XJ Cherokee
Freeze Plug Size
For all those who have dealt with Freeze Plugs on your Inline 6....
What size replacement Freeze Plug do i need to put back in?
I bought a rubber plug one ( They did not have any brass or steel ones in stock ) and it says it will fit 1 7/8" to 2" and it still leaked. It did not seal all the way... So i need to go up to what?
Stock 1997 Jeep XJ Country
RJC #377
StokedXJ11 is offline
post #2 of 4 Old 10-09-2006, 07:13 PM
BrunoS
go to any reputable engine rebuild shop and get one over the counter.
BIG TIME TIP: always smear the freeze plug hole with just a trace of RTV before you use a socket wrench socket to tap the freeze plug in place. It will seal perfect and never leak in the future.
Also: ALWAYS get the bronze freeze plugs. run away from 'coated' galvanized cheapo plugs. on freeze plugs...ALWAYS buy the better ones. also, always change your antifreeze when it's time...best way to avoid corroded freeze plugs.
Newly Painted! Emerald Green '96 XJ 4x4 4.0 HO 5-spd
3" Lift + 31" Tires / D35 TracLok / NP231
Drilled out Stock Airbox / Gauge Cluster Upgrade
Magnaflow Muffler / High-flo Cat / MSD Coil
BrunoS is offline
post #3 of 4 Old 10-12-2006, 05:48 PM
Jeepthing88
1994 XJ Cherokee
they arnt freeze plugs....thats VERY VERY important to know....they are core plugs...the only reason they are there is to provide a way to get the sand out after the molding process on the block.....they are NOT designed to pop out.....sometimes they might....but they arnt designed....just to let you know
94 Cherokee Sport
3" Rusty's Full Spring Pack
31X10.50 BFG Mud Terrain's on Crager Soft 8's
Jeepthing88 is offline
post #4 of 4 Old 10-12-2006, 06:01 PM
AZ Jeff
2014 JK Wrangler
While you are technically correct, everyone still calls them freeze plugs, even engine builders and machine shops.
AZ-Jeff
I don't own an XJ any longer, but I still think they are the best of all the Jeep products ever made. My XJ was my favorite vehicle in my 50+ years of driving.
So...I stick around and give advice.
AZ Jeff is offline
anti freeze plug? jjg214 XJ Cherokee Technical Forum 5 03-08-2009 07:51 PM
freeze plug replacement. sprintagogo XJ Cherokee Technical Forum 2 10-05-2008 12:50 PM
Pretty freeze plug!! xjman4life XJ Cherokee Technical Forum 11 05-31-2007 02:48 PM
Freeze Plug StokedXJ11 XJ Cherokee Technical Forum 4 10-08-2006 03:09 PM
Freeze Plug StokedXJ11 XJ Cherokee Technical Forum 7 01-21-2006 03:05 PM
