Freeze Plug - JeepForum.com
post #1 of 10 Old 12-05-2011, 03:18 PM Thread Starter
LOT3
Freeze Plug
Has anyone replaced the rear freeze plug closest to the firewall? I am trying to go through the firewall from the inside to install a steel plug.. any suggetions would be greatly appreciated..
LOT3 is offline
post #2 of 10 Old 12-05-2011, 06:20 PM
Rmart30
i dont think I would try to go thru the firewall.... you can get a rubber expansion plug at most auto parts stores to go in place of the freeze plug and they work quite well..no hammering in , just install and tighten the nut to make it expand. 20 min job if ya already got old freeze plug out.
Currently own 93 XJ 33's on 4" lift....01 XJ stock,will replace my 93 after mods are done..... 1994 ZJ V8, BB w/31's........99 XJ stock....97 XJ 2wd 5 spd stock.... and just p/u a 98 XJ 4wd/5 spd and a 01 XJ
Rmart30 is offline
post #3 of 10 Old 12-05-2011, 10:10 PM
Rob K
1995 XJ Cherokee
There was someone on the forum that was using the rubber expansion plugs in the back of the head. They kept blowing out. Wish I could remember the thread. I think they finally pulled the head and put a metal one in.
Rob K is offline
post #4 of 10 Old 12-06-2011, 07:42 AM
Rmart30
I would try one before I pulled a head or tried to cut thru a firewall. I have used many of the expansion plugs over the last 20 years on everything from automotive up to V 12 Detroits and only had one blow out and it was my fault because it was the wrong size.
Rmart30 is offline
post #5 of 10 Old 12-06-2011, 04:17 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
They used to make a brass one with a stud and nut in the middle, in various standard sizes. Tighten the nut and it expanded out tightly.
cruiser54 is offline
post #6 of 10 Old 12-06-2011, 04:34 PM
Diamond-x
1991 XJ Cherokee
A few suggestions:
Pull the engine out and do it correctly, unless you have good access to the plug thru the FW.
Use a brass plug, as mentioned previously.
Use a bit of lock-tite around the plug before installing.
Use a large socket that fits just inside the lip of the plug and hammer it home.
Diamond-x is offline
post #7 of 10 Old 12-06-2011, 06:13 PM Thread Starter
LOT3
i appreciate the replies... i have put the rubber adjustable plug in ---it keeps blowing out. taking the dash apart probably took as long as it would have taken to pull the engine !#@$@#.. i think i have to try the firewall direction.. unless i have problems with the heater core! i will update as i proceed.. thanks again for all the input.. all suggestions are apprecated
LOT3 is offline
post #8 of 10 Old 12-06-2011, 06:33 PM
Carves
Yep .... Had it on a hoist doing some stuff .... angled the back of the motor enough to get at the block and head, welch/freeze plugs.
Gearbox was out at the time ... remove the fan blades too.
Personally .... I'll be ripping the engine out next time ...
Theres a bunch of writeups around ... gojeep and others.
If one needs doing ... they probably all ( 7 ) do
Carves is offline
post #9 of 10 Old 12-06-2011, 10:01 PM
ChiliPepperXJ
2006 WK
Did mine last summer...just went ahead and pulled the engine..some pics can be seen in my build thread....good luck! ha
ChiliPepperXJ is offline
post #10 of 10 Old 12-12-2011, 09:53 AM Thread Starter
LOT3
Success! The good news is with 2 people dash removal to the firewall can be less than a hr job! Created a access port to easily access the freeze plug, tried the rubber expandable plug but could not get it to seal properly because of the contour of the head.. went back in with a brass freeze plug and no leaks (so far).
after trial & error arpox 3 hr job
Thank for all the help and advice-
unfortunately no pics – someone stole my camera..
LOT3 is offline
freeze plug replacement. sprintagogo XJ Cherokee Technical Forum 2 10-05-2008 11:50 AM
Freeze plug costs Gsmyth75 XJ Cherokee Technical Forum 5 11-11-2007 10:13 AM
95 Freeze Plug replacement Bernatos XJ Cherokee Technical Forum 2 07-24-2007 09:18 AM
Freeze Plug StokedXJ11 XJ Cherokee Technical Forum 4 10-08-2006 02:09 PM
Freeze Plug StokedXJ11 XJ Cherokee Technical Forum 7 01-21-2006 02:05 PM
