Four wheel drive in reverse? - JeepForum.com
post #1 of 6 Old 01-31-2003, 01:23 PM Thread Starter
White-Knight
Hey, got a question for everyone...I was backing out of a friend's driveway that is very snowy/icy and about at the top I got stuck with my tires spinning. So I popped it into four wheel drive, but it didn't work. As soon as I moved the lever I heard this grinding noise and then the lever stopped before it reached the 4HI position and I wasn't able to get it to go into position. So I put it back into 2wd and was able to eventually get out. Once I did, I tried 4wd again when I was in Drive (previously I had been in reverse) and everything worked perfectly. Are you not able to engage the system while moving in reverse? Or maybe I just didn't pull it hard enough, but like I said I tried moving it right after it stopped and it wouldn't budge any further towards 4HI. Any ideas? And also, I know that grinding in the case is bad, but is the Command-Trac pretty stout? I keep hearing mixed opinions on it's durability. Basically I'm just hoping that I didn't mess anything up. I don't think I did since everything worked fine after that, but still, just curious.
Thanks.
'96 Jeep Cherokee Sport (Moss Green, 4.0L HO, automatic transmission and Command-Trac transfer case, Custom 4x4 Tow Hook brackets and hooks, Class III receiver, Blazer 55w Fog Lights). Green Jeep Club Member #17
White-Knight is offline
post #2 of 6 Old 01-31-2003, 03:08 PM
ageofzeppelin
I used to have that problem to (the grinding, not the reverse but I have a 5 speed, so...) and the hard to shift issue. It hasn't happened since I changed the oil in the t-case, which may or may not be a fluke. From my experience, the t-case should hold up to just a little grinding because mine still works like a charm. It's obviously not something to try and do alot, but I wouldn't sweat the one time.
On a separate note, unless I'm moving I always shift to Neutral before I mess with the t-case.
1993 XJ Sport
4.0L, HO
5-speed Manual
235's and a few other little things.
ageofzeppelin is offline
post #3 of 6 Old 01-31-2003, 04:32 PM
RedJeepXJ
tcase
I have occasionally had this problem(grinding noise), what type of fluid do you put in there, such as is it the same as the tranny, I think it was dexron mercron 3?
thanks
RedJeepXJ is offline
post #4 of 6 Old 02-01-2003, 02:20 AM
EricsXJ
The Post man
EricsXJ's Avatar
Re: tcase
Yes, the transfer case takes ATF dexron III or mercon (Mobil1 synthetic ATF is good too if you want synthetic)
Eric
2000 XJ "PROJECT RUBICON" 3-link front / 4-link rear / coilovers / running 37's on Dana 60s
My website -
EricsXJ is offline
post #5 of 6 Old 02-01-2003, 08:56 AM
williak
It wasn't the direction (forward or reverse), it was the fact that the front end was not turning the same speed as the rear end. Learned that lesson the hard way. Make shure all (ALL) your wheels are turning the same speed or stop them completelly before trying to go into 4wd. Otherwise, grinding will be the least of your wories. My mitake snapped the driveshaft and put it in the oil pan. As for hard pull in, a good oil does help.
williak is offline
post #6 of 6 Old 02-01-2003, 03:39 PM Thread Starter
White-Knight
Thanks for your advice guys - I generally only use four wheel drive when I'm going forwards anyways. Oh well, now I'll just make sure to only engage it when I'm going straight forwards. Thanks again.
(Shameless plug - if you know anything about the heating system in a '96 XJ, then check out my other thread if you have the time: http://www.jeepforum.com/forum/showt...threadid=28328 )
Jerk into drive/reverse apoto11 XJ Cherokee Technical Forum 31 12-07-2015 09:00 AM
4.0 runs bad in reverse but good in drive ehames005 XJ Cherokee Technical Forum 3 12-17-2009 05:33 PM
Seems like I am being held back in Drive, but not Reverse?? nrpalmer32 XJ Cherokee Technical Forum 8 08-07-2009 01:20 PM
Stutter when in reverse or drive tozier9 XJ Cherokee Technical Forum 0 07-18-2009 02:47 PM
clunking from reverse to drive blacky_j XJ Cherokee Technical Forum 12 01-30-2009 06:14 PM
