Found a neat fog light wiring diagram... But whats this? - JeepForum.com
post #1 of 15 Old 02-11-2007, 02:06 PM Thread Starter
Jmila1901
Jmila1901's Avatar
Fog Light Wiring Diagram
My question is on the on/off toggle switch do you really need that off cable going to the fuse box? thats the part i dont get
Justin Mila
1993 Country XJ- AW4, 4.0 HO, Chy 8.25, Homebrew K&N Intake... DailyDriver
2002 Laredo WJ- Broken Bumper Mod... Weekend Toy
2007 Nike Dunks Size 12... Backup
Blue Jeep Club Member # 221
Originally Posted by KeepRockin024
You know your drunk when you have a little to much blood in your alcohol stream
Jmila1901 is offline
post #2 of 15 Old 02-11-2007, 02:08 PM Thread Starter
Jmila1901
Jmila1901's Avatar
Click free
Justin Mila
post #3 of 15 Old 02-11-2007, 02:13 PM
UltimatE
Resident Audio Guru
UltimatE's Avatar
I love that diagram, its the one I use most often. The point of the wire going to the fuse box is the 12v+ switched wire, such that it is impossible to leave your lights on with the ignition off.
Edit: That's not an "off wire" That switch is a SPST (Single pole, single throw) Its the 12v source to trip the relay when the switch is turned on.
-Matt
White '94 YJ Sport
Green '94 XJ Sport - 57,000 Original miles
UltimatE is offline
post #4 of 15 Old 02-11-2007, 02:16 PM Thread Starter
Jmila1901
Jmila1901's Avatar
Do you need it??? My electrical skills are horrible lol...
Justin Mila
post #5 of 15 Old 02-11-2007, 03:09 PM
madrabbitt
madrabbitt's Avatar
its what gives power to the switch.
look at this sorta flow chart and see if you understand.
12 volt source like fusebox or battery -> feeds 12 volts into the switch -> the switch is turned on feeding that 12 volts of power to the number 85 pin on the relay turning the relay on -> pulling the big *** load of power from the battery in pin 30 -> feeding that battery power to the lights -> poof. you have daylight at night.
the only thing i dont like about that diagram is that it uses an older style non lighted switch with seperate pilot light
Installing HID's in stock housings is bad.
"When you see someone who needs help, help them. When you see someone who needs a hug, hug them... Help those who can't help themselves." -Sgt Andrew Tingwall, NMSP. End of watch 6-10-2009
madrabbitt is offline
post #6 of 15 Old 02-11-2007, 03:10 PM
speighd
The line going to the fuse box is needed.
It it the "hot" side of the switch.
I agree with ULTIMATE157.
The circuit uses a relay to give power to the lights so it doesn't have to go through the on/off switch and overload it. With the relay you can uses a smaller switch.
It is very much like the circuit for a starter.
91 YJ Red Jeep Club Member #305
94 XJ
85 CJ-7
"Those that would give up their liberty for security deserve neither liberty nor security"
-Benjamin Franklin
speighd is offline
post #7 of 15 Old 02-11-2007, 03:16 PM Thread Starter
Jmila1901
Jmila1901's Avatar
Does anyone have any pictures of the wiring on their car?? i would really appreciate it if you would take a few pointing out where it runs through. Instead of lighting up the road with fog lights i might end up lighting the road with my flaming car lol....
Justin Mila
post #8 of 15 Old 02-11-2007, 06:47 PM
dynorockcg
dynorockcg is offline
post #9 of 15 Old 02-11-2007, 06:53 PM
XJHERO
XJHERO's Avatar
isnt the wire going to the fusebox so that you can leave the switch in the on position and not have to worry about turning the switch off when you turn off the engine. kinda like daytime running lights in the sense that when you turn the truck on the lights come on? unless of course you flip the switch off?
P.S. im electrically retarded
98 XJ.
4.0 HO - AW4 - NP 231 - DANA 30, CHRYSLER 8.25
4.5" RE SUPER FLEX KIT, 32x11.50 BFG KM's
DIFF GUARDS, ENGINE AND TRANS SKID, CB
XJHERO is offline
post #10 of 15 Old 02-11-2007, 06:59 PM
UltimatE
Resident Audio Guru
UltimatE's Avatar
Thats exactly why that particular wire is run from/to the fuse box. You have the 12v+ wire for the switch on an ignition circuit so that you don't have to turn off the switch when you turn off the ignition. If you want to have the lights off while driving, just throw the switch off.
-Matt
White '94 YJ Sport
UltimatE is offline
post #11 of 15 Old 02-11-2007, 07:06 PM
Rescue XJ
That diagram does not reflect the 87 and 87a pins being hot. You should run a wire to each light from the relay, one from the 87 pin and one from the 87a pin.
White 96 XJ Sport
Jeepforum Minister of Sarcasim
4L HO Command track Dana 30 front Chrysler 8.25 rear CarQuest XD shocks, Federal Signal emergency stuff, MCX 1000 DES-XL, TK-940, Astro Spectra W3 encrypted, Magnaflow 18" body, Medical supplies, MREs, Gatoraid, Shovel, MagLite, body armor, grappling hook, annoying squeeking sound from my door, otherwise stock for now.
White Jeep Club Member #911
Code 3 Jeep Club Member #1
Eagle Scout Jeep Club Member #2
Originally Posted by tx50cj3a
Vatozone.
Originally Posted by 92 Briarwood
I think "that look" is what they teach the chicks in 6th grade when they show them "that film" behind closed doors.
Rescue XJ is offline
post #12 of 15 Old 02-11-2007, 07:32 PM
TheInstaller
TheInstaller's Avatar
1993 XJ Cherokee
87a is normally closed. If you connected one light to that, it would go on when the fog light switch was off, and be off when the switch was on. There are some relays that have 2 pin 87's. In that case you would run one light to each pin.
-Jeff
1993 XJ Sport, AX15, NP231, D30 open, Chrysler 8.25 open, Rusty's 3" lift with full packs, Firestone Destination A/T 235/75/15's, Uniden PC68XL CB radio, Custom rock sliders, custom intake, trimmed fenders, custom front bumper, 2" receiver front and rear, 48" Hi-Lift jack, OBA.
TheInstaller is offline
post #13 of 15 Old 02-11-2007, 08:04 PM
UltimatE
Resident Audio Guru
UltimatE's Avatar
What he said. A relay with 87A is a double pole single throw (DPST) relay.
-Matt
White '94 YJ Sport
UltimatE is offline
post #14 of 15 Old 02-11-2007, 08:37 PM
madrabbitt
madrabbitt's Avatar
yeah. drew musta had a case of the drive by dumbs.
87a is a normally closed contact. you use one or the other depending on your requirement (do you need the circut ON or OFF when the relay is energized)
Other relays have two pin 87's or the second says 87x.
The diagram is right.
post #15 of 15 Old 09-30-2009, 03:03 AM
Justin123
1990 MJ Comanche
you should just get a llighted switch. that way, if you leave the lights on, there is a red light mounted somewhere you can see it. it's sooooo much easier, and it looks cool.
3 lift. dropped transfercase. 31x10.5 BFG All Terains. side pipe right after cat. intake. SLR programmer.
Justin123 is offline
Look what I found! Whats it for? Haleyrz XJ Cherokee Technical Forum 11 09-29-2009 06:37 PM
Mix matched wiring harness/engine/tranny.........could use a wiring diagram dadstoy XJ Cherokee Technical Forum 1 08-15-2009 12:58 PM
Scored a Trailer Wiring Harness at Junk Yard for $0, need wiring diagram photonut13 XJ Cherokee Technical Forum 1 04-12-2008 02:39 PM
A neat Jeep Cherokee vid I found... Koenig XJ Cherokee Technical Forum 31 08-04-2006 11:59 AM
Wiring diagram TBLimited XJ Cherokee Technical Forum 1 05-18-2005 07:57 PM
