Ford 8.8 Rear Axle Question - were to mount the shocks for best performance? - Page 2 - JeepForum.com
post #16 of 23 Old 07-12-2010, 07:49 PM
99Greenmachine
Originally Posted by cornbrizzle View Post
Axle Side Mount Shock Brackets [06091840] - $24.00
use something like these and mount them even with the bottom of the axel tube and as far out as you can. Like the picture Postaldave posted above , but with these you don't have to angle them, theay are double shear and the shock will rotate on the bolt .
just my .02
I think me and justanthrjpr came to the conclusion that single shear were much more trail-friendly should something go wrong haha
'99 XJ Sport
Thank You Hooligan!!!
[SIZE="4"]XJ Dana 44, Yukon 4.56 D44 Gears, LeBaron hood vents for sale
99Greenmachine is offline
post #17 of 23 Old 07-12-2010, 08:25 PM
96fleXJ
nice pics and shock info! I got my 8.8 ready to get welded up tommrow. Cant wait!
Kinda off topic but ive read that I might need a SYE with the 8.8 because the pumpkin is offset is this true?
I know the 8.8 lifts the jeep about and inch because of the axle tubes but if i take out a leaf of the spring pack and be back around 4 inches ( where I am now) would i still need a SYE ( I dont get any vibes right now BTW)
sorry about being off topic yall!
96fleXJ is offline
post #18 of 23 Old 07-14-2010, 09:27 AM Thread Starter
fla_cracker
1995 XJ Cherokee
Greenmachine,
Silly question.........."single shear"? this is my educational moment...I'm feeling kinda dumb
good question 96fleXJ...
"Only two things are infinite, the universe and human stupidity, and I'm not sure about the former. "
Albert Einstein
Originally Posted by N2Fix View Post
"somewhere between really crappy and kind-of-crappy gas mileage."
fla_cracker is offline
post #19 of 23 Old 07-14-2010, 10:05 AM
cornbrizzle
1992 XJ Cherokee
How's that? single shear you remove the nut off the stud . double shear you remove the bolt that runs thru. the shock bottom bushing ? seems like about the same amount of work, which in both cases is not much?
just my .02
Brizzle
“Don’t Tread On Me”
www.highsprings.com
cornbrizzle is offline
post #20 of 23 Old 07-14-2010, 10:11 AM
99Greenmachine
Well it's been a while since it got brought up but i remember when I was building my D44 we got in this discussion about how he had broken a mount on the trail and the double shear was hard to fix. I elected to keep the original single shear OEM shock mounts.
I will go back in the archives and try to find our exact conversation for everyone's benefit
'99 XJ Sport
post #21 of 23 Old 07-14-2010, 10:19 AM
99Greenmachine
Here I found it...it was in my build thread haha:
http://www.jeepforum.com/forum/f11/g...ml#post7693633
'99 XJ Sport
post #22 of 23 Old 07-14-2010, 03:14 PM Thread Starter
fla_cracker
1995 XJ Cherokee
Thanks Greenmachine,
I will be doing my part and recycling the mounts from the 35. Looks easy and cheap. Both up my alley.
Also nice build thread.
Albert Einstein
post #23 of 23 Old 09-24-2010, 09:23 AM Thread Starter
fla_cracker
1995 XJ Cherokee
Up date.....
OK,
I recycled the D35 mounts. In an effort to make it easy and keep the shocks out of harms way, I mounted them center of the axle tubing.
When I did this the JK shocks that I had been using were too long. Less than 1" from bottoming out. This was before removing the BPE's. It turns out that the original XJ shocks are a workable length. So for now, until fine tuning is done, this is what I will run.
On another note......The rear of the XJ was lifted about 1.25". This was using after market spring perches on the 8.8. I was thinking that I would have to install my SYE because my driveshaft was already looking short with the original lift.
Upon inspection after finishing the 8.8 I realized that the 8.8 is longer in the nose and actually pushed the driveshaft forward close to were it was before any lift. The only thing I had to do was take the dremmel tool to the slip yoke end of the driveshaft to allow for more angle on the u-joint. No vibes were made either.
Albert Einstein
8.8 , build , shock , mount , location
Ford 8in rear axle swap Crush03 XJ Cherokee Technical Forum 3 06-13-2010 04:06 PM
MOPAR® Performance Rear Dana 44 Axle NowMed XJ Cherokee Technical Forum 12 02-22-2010 03:28 PM
New upper mount for rear shocks? medicbear XJ Cherokee Technical Forum 3 01-14-2008 04:50 PM
FORD 8.8 Rear and what about the FRONT AXLE CJ7Dex XJ Cherokee Technical Forum 4 10-27-2007 09:46 PM
Found a Ford 9" Rear Axle Jeepin_XJ_101 XJ Cherokee Technical Forum 7 03-19-2006 01:57 PM
