Ford 8.8 Lug Nut Size - JeepForum.com
post #1 of 4 Old 07-28-2009, 10:03 PM Thread Starter
rc76
What is the Ford 8.8 lug nut size?
Thanks!
~ Russ
98 Cherokee Sport- 4.5", AA SYE and TW Shaft, 33" Cooper Discoverer STTs, XCr8000, Jcroffroad Stage 2 Winch Bumper , 60" Hi-lift, Cobra Ultra III, Gragar Soft 8s, Detour Tail Bone, jcr Offroad Stage 2 Sliders, RockCrusher Diff Covers Front, Lockright in the front, Aussie in the Rear (Ford 8.8) with 488s... More $$$ for Bank Account (On Back Order...)
99 Cherokee Sport- Stock and Staying that Way (Wife's DD)
rc76 is offline
post #2 of 4 Old 07-29-2009, 12:25 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
If your 8.8 is out of an Explorer, it should be 1/2"X20 RH (Right Hand thread) which I believe is the same as your XJ.
You can check it out for sure at www.mcgard.com/Home/AutomotiveProducts if you know the year/make/model of the 8.8 donor vehicle.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #3 of 4 Old 07-29-2009, 05:38 AM
bmyohn
Youngin'
bmyohn's Avatar
should be the same as the XJ lug nut sizes
2014 Jeep Wrangler Sport S
3.6L V6 - Manual
2001 Jeep Cherokee Sport
4.6L Golen Engine Stroker
6.5" TnT Customs Longarm Kitl Ford HP D60 l 6.5" Rock Krawler Coils l TnT Customs HD Trac Barl Omix Ada HD SYE l 1" UBEsl CV Driveshaft l39.5" IROKsl 17x9" Pro Comp 98sl High Clearance Shock Mounts [COLOR="red"] l Hidden Hitch l AJs Custom Front Bumper l SONY Xplod stereo l Alpine Speakers l TnT Frame StiffenerZ l 22" RE SS Brake Lines l 1.5" TnT Customs Boomerang Shackles l Sterling 10.25 *FULL WIDTHS* l JKS Mini Skids and Sway Bar Brackets l 7/8" Heim Joint High Steer
bmyohn is offline
post #4 of 4 Old 07-29-2009, 06:34 AM Thread Starter
rc76
Yeah it's a late model with discs... just wanted to make sure before I went twisting them on.... thanks for the info!
rc76 is offline
Wheel Size/Tire Size Help. allibaster XJ Cherokee Technical Forum 7 10-16-2009 05:28 PM
Any got the socket size + torx screw size list? willcherokeexj XJ Cherokee Technical Forum 5 05-19-2009 11:23 PM
Ford D44 front axle...what size wheels??? Arcticcat843 XJ Cherokee Technical Forum 15 04-13-2008 10:41 AM
doing shocks tonight. need bolt size and nut size toates89 XJ Cherokee Technical Forum 1 01-14-2008 05:28 PM
D44 brake drum size/ shoe size Timo_90xj XJ Cherokee Technical Forum 4 12-05-2006 07:32 PM
