Ford 302 swap in XJ - JeepForum.com
post #1 of 12 Old 02-02-2010, 09:46 PM Thread Starter
89cherokee352
1989 XJ Cherokee
Ford 302 swap in XJ
Been tossing the idea around of doing a 302 swap in my XJ. Im a chevy guy at heart but I know the ford transfer case comes out on the same side as the XJ just figured it'd be an easier install. Any input on this. I've heard of a few guys with cj's and possibly YJ's using chevy motors and trans with an adapter plate to the jeep transfercase. Would that also work with an XJ. I love my straight 6 but theres only so much I can do with it. Any input or info would be appreciated. Thanks
89 Cherokee 4dr. 6" lift front 5.5" lift rear. Comp Cut on 38x12.50 TSL's w/ 15x10 MB motoring Wheels
89cherokee352 is offline
post #2 of 12 Old 02-02-2010, 10:45 PM
pentastar01
Why not a Mopar 318 or 360. I honestly don't know much on the topic but the way I figure it, a 4.0 and a 5.2/5.9 could be dropped into a ZJ. Maybe the engine mounts(or the brackets) are similar enough to make it a somewhat easy swap into an XJ. Although I could be dead wrong, but it's worth looking into.
Life's tough, that's why I drive a Jeep. Until it breaks, then life's a *****.
pentastar01 is offline
post #3 of 12 Old 02-02-2010, 11:04 PM Thread Starter
89cherokee352
1989 XJ Cherokee
Never thought of that actually. Definately something to look into. Whatever I build is going to be carbureted. I may just rebuild my 4.0 but who know's. I would like ot get some input now to figure out what I am going to do.
post #4 of 12 Old 02-02-2010, 11:15 PM
bmyohn
Youngin'
bmyohn's Avatar
Try this forum as well: Engines & Drivetrain
A lot of guys on there have knowledge on various motors, they may be able to give you a better idea on what is involved in this type of swap.
Best of luck,
Brendan
2014 Jeep Wrangler Sport S
3.6L V6 - Manual
2001 Jeep Cherokee Sport
4.6L Golen Engine Stroker
6.5" TnT Customs Longarm Kitl Ford HP D60 l 6.5" Rock Krawler Coils l TnT Customs HD Trac Barl Omix Ada HD SYE l 1" UBEsl CV Driveshaft l39.5" IROKsl 17x9" Pro Comp 98sl High Clearance Shock Mounts [COLOR="red"] l Hidden Hitch l AJs Custom Front Bumper l SONY Xplod stereo l Alpine Speakers l TnT Frame StiffenerZ l 22" RE SS Brake Lines l 1.5" TnT Customs Boomerang Shackles l Sterling 10.25 *FULL WIDTHS* l JKS Mini Skids and Sway Bar Brackets l 7/8" Heim Joint High Steer
bmyohn is offline
post #5 of 12 Old 02-02-2010, 11:29 PM Thread Starter
89cherokee352
1989 XJ Cherokee
Thanks, off topic but do you have a build thread for your xj, that parts list looks serious...
post #6 of 12 Old 02-03-2010, 05:10 AM
iwishihad1
dont let motor mounts be a deciding factor of your build. putting motor mounts in for a swap is by far the easiest part of the swap, and the cheapest. things to think about are wiring, adaptor plates, tranny/tcase options, drivetrain length, etc.
novak has a lot of support for putting a 350 in to an XJ along with advance adapters. if i were to take any route id go chevy small block/tranny. simply for the reason that I would have to fab the least amount of parts, and the knowledge is easily available
[CENTER]1995 fire red XJ, new 4.0, ARB safari snorkel, sye, front DS, aussie locked 8.8 5:13s 38 SXs, trussed/locked 44 front, hydro assist, DOM steering/COLOR]
YJ. 91 body, body off resto, crate chevy 350, 700r tranny, 2 inch springs, SOA, ford 9 rear, dana 44 front, both detroits, cage, 4:88s, and 36X14.50s. strictly street queen
iwishihad1 is offline
post #7 of 12 Old 02-03-2010, 08:21 AM Thread Starter
89cherokee352
1989 XJ Cherokee
I didn't realize they had the mounts and adapter plates for a XJ. So I am able to run a 350 and turbo 350 trans and mate that up to the XJ's transfer case with what Novak supplies then. I apologize for my ignorance, but I'm still getting up to par in the jeep world
post #8 of 12 Old 02-03-2010, 11:14 AM
bmyohn
Youngin'
bmyohn's Avatar
Yep I do, http://www.jeepforum.com/forum/f11/b...begins-440087/
3.6L V6 - Manual
bmyohn is offline
post #9 of 12 Old 02-03-2010, 02:11 PM Thread Starter
89cherokee352
1989 XJ Cherokee
looks awesome. you can check out my build thread if you want, Its title budget built XJ, just your typical xj on 38's....
post #10 of 12 Old 02-03-2010, 04:00 PM Thread Starter
89cherokee352
1989 XJ Cherokee
One more question, how well would an xj's transfer case hold up to a mildly built 350 with a turbo 350 or 700r4 trans. I know mine takes all the abuse I can throw at it but when you start putting a lot of power to things you never know the outcome
post #11 of 12 Old 02-03-2010, 04:25 PM
bmyohn
Youngin'
bmyohn's Avatar
Build thread looks good! I'm interested in how that D30 holds up the those tires. I am ordering some 37s for my jeep in a few weeks. I'll have to put the D30 through its paces.
3.6L V6 - Manual
bmyohn is offline
post #12 of 12 Old 02-03-2010, 05:02 PM Thread Starter
89cherokee352
1989 XJ Cherokee
I will let you know how they hold, Im givin it hell this weekend to see what all will break. My poor 4.0L might be the first to go though, Unfortunately the previous owner didn't take very good care of it before I got it. That's why I'm looking into a few different options
ford 8.8 swap LIsurfcasters XJ Cherokee Technical Forum 10 01-11-2010 01:55 PM
Ford 8.8 axle swap? Cherokeegrrl XJ Cherokee Technical Forum 22 05-16-2008 03:50 PM
my ford 9 inch swap white_elephant XJ Cherokee Technical Forum 5 12-04-2007 10:09 AM
Ford 302 v8 swap Gsmyth75 XJ Cherokee Technical Forum 5 04-24-2007 05:17 AM
Ford T18 3 speed swap oldblue XJ Cherokee Technical Forum 5 11-07-2003 05:19 AM
