This is for you engine builders out there. Can I run a OBDII system with a OBDI system flywheel? (crank position sensor stuff) OBDI has notches all around the flywheel, the OBDII has just 3 sections with notches. If I need the OBDII, anyone know if the crank shaft bolt hole pattern is different from the OBDI? I'm Using a 92 4.0 block that I made into a a 4.7 stroker with the 4.2 crank.
thanks
thanks
